thinking of selling my R32 gts-t,
it has,
RB30 block
RB25de head with n/a cams
gtr injectors
malpassi dual diaphram rising rate fuel reg
bosh 044 pump
GT 3076r garrett turbo running 20psi
am performance dump pipe/screamer
microtech lt 12s computer
oil catch can
300x600x75 fmic with 2.5" cooler pipes
3.5" exhaust
19x10 and 19x8 Koya wheels
pioneer stereo with 12" sub
very tidy interior
"SKYLINE" custom number plates
no pretty bits under the bonnet (tried to keep it looking stock)
very nice looking car
awesome fun to drive, engine has NO blow by and runs A1, very quick car (when it gets grip)
ph. 0458977006 or pm me
Edited by HECTIC
https://www.sau.com.au/forums/topic/318495-r32-gts-t-rb-2530-conversion/
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
