So what your saying is that ben will help SAU members out and give them a discount but SAU vic will not help ben out and send work his way at a non discounted rate?
Also i notice that no one is mentioning his price, so in the end you HAVE to join SAU vic to get his number to find out what his price is, im not a trusting person and all of this sounds like the ground work for a scam.
Oh now now... A scam? Please. We are protecting an arrangement that we have organised for CLUB MEMBERS.
Hell members are posting up themselves saying how good the value is. If you need more proof then well you'll never get it.
If i told you all the details... what will stop you going to him and saying "I'm a memeber"? When you really aren't? :(
If you think it's all some big conspiracy/scam/whatever then just go to any retail alarm installer and pay full price that way. They are all around the same give/take.
tufff thanks charles.. will join the club soon :rofl:
Lol np. Just to clear things up, I'm only giving you the info you wanted, not trying to con you into a little "scam" as someone suggested.
At the end of the day, it is up to you to take that advice or not :P
I paid approx $250 from memory for a fully installed alarm on a 1996 Ford Falcon, I believe this may have included a battery backup add-on as well.
The car did not have an alarm, and I'm unsure what the price would be for a skyline.
EDIT: the membership price for SAU would offset the price to get an alarm at this price. Also note that I bought the plain alarm system, nothing fancy.
Now that wasn't so difficult? Thanks for that info.
Well then does he install the Mongoose alarm with 3 point immobilizer, alarm, supersonic sensor, battery back up siren? Or is there a better one he does?
(Quote from Stylyn audio: $599 installed)
Edited by TyresBro
which stylin, friend of a friend manages one.
"http://www.stylyn.com/
Stylyn- Focal, MB Quartz, RockFord Fosgate, Alpine, ALARMS etc
268 Dorset Rd, Boronia - (03) 9739 8866" (Local Wreckers And Workshops thread)
Just called the number and got a quick quote cause didn't know much about alarms lol. Said he was doing one on a Subaru Liberty at the time and could do one for me for $599 (doesn't sound too cheap for some reason heh).
  • 1 year later...
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
