TV Head unit??
Guest mooks66
5% tints my friend.
tvs are illegal while your driving thats right, but what the cops cant see wont hurt eh.
but dont be a hero and show it off while your driving though... not only will sum1 follow you and rip your car apart, but you just might get distracted with some jenna jameson action and lost concentration on the road. Putting your life and sum1 else's at risk
hehehe
https://www.sau.com.au/forums/topic/3185-tv-head-unit/#findComment-54347
Guest Miss_Nismo
If you get installed professionally i think they are required by law to hook it up so it will only play tv/dvd/vcd when the handbrake is up, there is ways around this though, like putting your handbrake up on notch, if you are getting it installed by the dealer then just ask them if they can do it legal but dodgey :lol:
https://www.sau.com.au/forums/topic/3185-tv-head-unit/#findComment-58004
man that suxz....wanna watch some porn while drivin :) :shake: :shake:
https://www.sau.com.au/forums/topic/3185-tv-head-unit/#findComment-58796
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
