Yes you heard it right, I'm looking at selling off my original Series 2 Dayz front bar for the right price. If I can't get the right price, I'll repair it to replace the Blits Dolphin copy front bar on at the moment and sell that instead as I am still quite fond of the Dayz bar :)
As far as I can tell, apart from the scratches and dents, the 2 main repair jobs are the 2"-3" tear underneath on the right hand side and the mounting bit on the top right, both as circled in the piccys. Will sell with the spotlights, the air vent/scoop thing, and the little bit that came off the mounting bit to be repaired.
Will post interstate if you organise the courier/packaging/pickup etc.
PM me if you want a higher res image to be emailed.
Offers?
Edited by webng
https://www.sau.com.au/forums/topic/318515-adl-s2-dayz-front-bar-for-sale/
You will need to post a price
You could do everyone a favor and con someone to make a mould for free, so then they could sell them
Do you have decent bodykit shops in Adelaide?
Just an idea
Just an idea
Not sure what it's worth. Let's say an instant of $500.
Can the factory plastic bars be repaired?
It's plastic, they can do a lot with plastic as it has memory and they can fuse and weld it nowadays apparently.
Plastic bars can be repaired or modified - I removed no. plate surround and centre section and repaired a few cracks on mine.
Soldering iron to melt and weld, bit of fibreglass to support from rear and bog top, heat gun works well if modifying.
Just bought it, condition isn't that bad, few scratches, side bracket come off and a small ding, nothing unrepairable as its needs painting.
Very rarely do they come up for sale and it saves me damaging my Takero bar that sits 2 inches off the ground.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
