Hi guys I am planning to make my Auto S2 Stagea mody to power between 230rwkw to 250rwkw, and I know what parts to get and I already start doing this now but until some of my friends who own WRX and 180sx they said my car will need to change the drive line or gearbox thing otherwise my car won't make pass 165rwkw. They said my 4wd system is same as wxr not strong , is this trust?? If I want to mody my S2 to 230rwkw then I will have to change the all the drive line , like gearbox or diff??
4WD will be fine, it's basically the same as the GTR 4WD system which can handle alot more than 250awkw. The auto box will handle it, I'm running around that power with a stock auto, my only issue is flaring in gearchanges under full load. I'm in the process of getting a shift kit to sort that out.
Edited by QWK32
no, the AWD system is actually based on the GT4 which was NA - the only GTR based systems were in the Autech. Its kinda interesting really, the stagea was the ONLY RB25DET powered AWD system Nissan ever made...
Yes the gearbox will handle it, as will the diffs, transfer case etc, but to make sure I would recommend a thermo controlled trans oil cooler and a shift kit as a sensible precaution
While looking for a shift kit for my re5, I was told the re4 was good for over 1000 hp once built.
+1 A shift kit will help stop the wearing clutch slip that occurs when powering up the engine.
Yes, and the re4 is a much stronger box. M35 uses the electronic throttle to limit the torque so they could lighten the box a bit.
So mine S2 stagea autobox can hold 1000hp? then should be enought to handle 250rwkw as well.
You will definately need a higher rated torque converter at that power. Mine sucked ass with the stock converter...
When mine was stock, my 60ft was 1.9. With the 30R+other mods and stock converter, it was 2.2.
Haven't run it yet with the higher stall, but feels ALOT better with it!
Only once built. I guess any more than around 200kw you would need the shift kit fitted at a minimum.
where can i buy the shift kit for my S2 stagea? from ebay? or import monster?how is the shift kit look like? i am sorry i know nothing about car thing.
Pretty sure that MV Automatics have shift kits for your car
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
