  • 9 months later...
anyone ever find a part number for these? or an appropriate aftermarket unit?
You'd be better getting a strut Re-gas guy to measure up and obtain something suitable.
The issue will be the door end, as the bracket & ball is permanently affixed.
Is there a reason yours can't be regassed?
There a few places online where you can buy custom Struts, you give them the measurements and weights and what ends the struts need and they will make them up. (most if not all the stagea's have ball joint ends, fairly common)
Im sure if we get a few people interested we could see about a group buy with a strut making company....
  • 4 months later...
I processor detective work in the dark in the garage in the morning. I took the gas spring to the desktop and I did the measurements and I found using Google the UK company that produces the desired gas spring lifting force. I examine the dimensions in the manufacturer's pages and I got to the shopping cart products:
http://www.sgs-engineering.com
Original gas strut includes a coarse threaded ball sockets so I have to buy new ball sockets with M8 thread. Also original gas strut is 1125N and i planned to order 1150N.
Gas spring original body length is 14 cm and a stroke length of 9cm so the total length of 23cm. This means that the GS10-22-100-150 will not physically fit in the car (gas strut body strikes to strut support iron when the backdoor is closed). This means that the manufacturer's catalog contains one of the appropriate gas spring GS10-22-70-120. This product is a body length of 2cm too short and the stroke length is also 2cm too short! This place is more suitable for shorter, with larger gas strut rear door can not be closed. If we replace B10 to B11 which is 6 mm longer so stroke length difference is now 14mm. So, the end result will be the door several centimeters lower.
My friend works at the selling company that imports the original STABILUS gas struts to Finland. I'll put him in the query that he have time to work on the sidejob to take a look availabilities and prices of original and possibly the bolt-on parts.
Now a moment to sleep. Whether others found other options?
  • Like 1
Guys, i have found the original STABILUS number for OEM lifts. They are 095303
http://www.klee.dk/en/products/linear-motion-technology/gas-springs-lift-o-mat/04095303/
for you this should be OK) near 30 USD + shipping
Edited by Erop
  • Like 2
  • 5 months later...
Can you (or anyone) confirm that these are correct? As it doesn't match exactly with what I have in my car.
Dragon92, If that is for an M35, please post up the part number.
K250-22-1135n
$35 each
(Helps when i know the guy i got them from)
I also ordered a 10mm add on otherwise the boot wouldn't open as far.
Edited by Dragon92
  • 1 year later...
No idea if you guys have found suitable replacements in OZ/NZ for your M35 Stagea tailgate and boot floor struts but I've just managed to order some new ones from SGS engineering in the UK. Cost about £100 / approx 160 AUD for all 4 struts.
Will let you know how I get on when they arrive!
  • 3 weeks later...
Hi John
Yeah I still have the invoice - the part codes on it are:
GS10-22-100-150 Gas strut
B10 10mm metal ball socket
B3 10mm angled plastic ball socket
GS8-18-100-140 gas strut
B1 10mm plastic ball socket
Not sure which is which strut but I can take a look if you're only wanting to order the boot struts for example.
Edited by gazman2
  • 1 year later...
Hi Gazman2
Did you install those GS10-22-100-150 gas struts to your Stagea? I have those same struts and I'm trying to
put those to my 2001 Stagea 300rx... How did you install those cause I'm having trouble because struts are
so strong ( seems that they might fit if there is a way to pull the strut rod inside couple of centimeters when installing )
Has anyone here actually installed those GS struts to Stagea?? Or are they simply not for Stageas...
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
