Hi Gazman2
Did you install those GS10-22-100-150 gas struts to your Stagea? I have those same struts and I'm trying to
put those to my 2001 Stagea 300rx... How did you install those cause I'm having trouble because struts are
so strong ( seems that they might fit if there is a way to pull the strut rod inside couple of centimeters when installing )
Has anyone here actually installed those GS struts to Stagea?? Or are they simply not for Stageas...
I installed them, no issues. Had to prop the boot open with a long bit of 2x4, but otherwise no dramas. I think once it was all off, I attached the boot lid bracket to the strut, then the bracket to the boot lid, then popped the strut on to the D pillar. Took a little bit of force but nothing serious.
  • 3 months later...
