that's not true, using 100RON is a great insurance policy on track days etc where you are worried about detonation without the skill (or ability) to back out timing from your tune or run less boost
but you can't buy 100RON so it doesn't matter. 98ron is all good
https://www.sau.com.au/forums/topic/318553-shell-petrol/#findComment-5205465
Like most I use bp 98 exclusively but had to change to the shell 98 when i went to wakie for 3 days of track madness recently.
the shell product never gave a hint of trouble and the plug colour was as good as ever it was with the bp.
Will continue to use the bp as it is only a kay from where i live but would have no probs using the shell product when the need arises.
A couple of years back when I was runing a pfc I did a holiday on the norhtern nsw coast. There waer 3 servos almost next door to each other so I filled up with 98 from bp, shell, and caltex on 3 different occasions and went cruising on much the same glorious roads each day.
The caltex was the surprise, It gave lower knock readings and the car ran better on it. draw your own conclusions but if i had the caltex 98 more readily available I would use it more often.
https://www.sau.com.au/forums/topic/318553-shell-petrol/#findComment-5205540
I'm not 100% sure, but I think most of those fuels come from the same refinery. The main difference is likely down to the freshness of the fuel.
IIRC BP, Shell, Mobil and Caltex supply each other fuel in different areas around the country, ie. pretty much all fuel in Melb comes from Mobil and Caltex as they have refineries here. BP and Shell supply Sydney and Northern NSW, and so on.
I'm sure someone here works in the industry and can clarify how it all works.
https://www.sau.com.au/forums/topic/318553-shell-petrol/#findComment-5205593
That sucks v power is 100 Octain in the UK
Even the Supermarkets sell 100 Octain lol
Personally I think its all a con anyway. I ran my car on 95 for over 2 years no problems even run a few 1/4 miles on it no problems managed a 14.27 pass @.5 bar 255bhp pritty much stock
Even managed 299bhp on the rollers on 95. and the a/f was said to be spot on. Although I will admit since the boost was increased and only since then it feels like it runs better on v power or the supermarket stuff.
But when it was stock 100 was not needed plus i can not believe that Nissan would have only mapped these engines to run on 100 or more they exported them all over the world in one form or another.
Just my 10 cents
https://www.sau.com.au/forums/topic/318553-shell-petrol/#findComment-5205612
It may well be fuel freshness, I am no expert on the fuel industry, I can only give the real world experience I had at that paticular time.
https://www.sau.com.au/forums/topic/318553-shell-petrol/#findComment-5205634
yes fuel companies share tanks and fuel as not all companies have refineries in every state so they share
and fuel does loose its octane count over time, so old fuel will certainly affect its level of resistance to knocking etc
this is more than likely to explain the level of resistance to knocking vs a specific brand
ie in some cases shell fuel will actually be mobil, and caltex may be BP
often i see people post up brand XYZ is evil and kills injectors, motors etc blah blah
i believe its more due to the fact of age of fuel at the servo vs a specific brand
https://www.sau.com.au/forums/topic/318553-shell-petrol/#findComment-5205817
Agreed. Used to get V-Power Racing when it was available and knock was eliminated almost completely. Struggled to get readings over 15 with 250rwkw, redlining in the middle of summer. Brilliant stuff.
United still sell 100RON
https://www.sau.com.au/forums/topic/318553-shell-petrol/#findComment-5205833
Shell have their own refinery here in Melbourne. The fuel terminal at Yarraville (under the westgate) is where all teh fuel truck fill up. They each lease the tanks from Shell and Mobil. Here's basically how it breaks down.
Shell have their own fuels
Caltex, Mobil and BP all share the same fuel under 98 Octane and e10 (in other words, they all get pumped out of the same tanks but put into different trucks)
Caltex has their own 98 fuel.
Mobil and BP share the same 98 but BP puts their own extra additives into it, what this means is that you can always turn Synergy 8000 into Ultimate but you can't turn Ultimate into Synergy.
As far as I'm aware they all get their e10 from the same place but get different blends of fuel to go into it hence the different RON they have. BP do have an e10 but it is not at the metro sites yet, only in the regional sites run by Reliance Petroleum.
Only reason I know all this is because I work for Reliance Petroleum who are the largest Australian distributor of BP Products. We are also a national distributor of Castrol.
I don't get a discount for working for them but I still use Ultimate as it has been the best performing in my car. I did also have great results with Caltex 98. I wouldn't use Shell V-Power personally unless there was no other choice, it goes stale quickly and loses it's octane rating faster than all the others, not sure why. I also got 80-90km less per tank out of it.
They say oils aint oils so I guess fuels arent fuels. I want to see the Ultimate 102 fuel that BP rolled out in the UK here but it's not going to happen now since they stopped selling it in March this year. The stuff would have been sweet Clicky!!
https://www.sau.com.au/forums/topic/318553-shell-petrol/#findComment-5206365
yeah and do you no how much they charge
Nearly $5 a lt!!!!!!
and its not on every bp fore court only selected places have it and I only come across ONE place and that was at Silverstone race circuit.
Or though the likes of santa pod drag stip will sell you 20lts of "race fuel" for about $150
Edited by jjskyline79
https://www.sau.com.au/forums/topic/318553-shell-petrol/#findComment-5207075
Isn't normal juice about $3.00/litre over there anyway?
https://www.sau.com.au/forums/topic/318553-shell-petrol/#findComment-5207506
they couldn't have t at every servo because there was no need too. It was made in small batches of 20,000L and was the same fuel used in F1 for the winter season for $5 per L it's pretty steep but they were selling plenty of it, pitty the refinery closed that was making it :cool:
https://www.sau.com.au/forums/topic/318553-shell-petrol/#findComment-5208345
The only reason v=power racing was 100ron was because they used ethanol to bump it up, what was bullshit about that is the fact that they sold it for 5c a litre more than the normal v=power 98ron. It dosen't make sense when you see e10 unleaded sell cheaper than regular unleaded.
I wish it was still easy to get race fuel for the odd track day but good old emission rules and regulation screwed that.
https://www.sau.com.au/forums/topic/318553-shell-petrol/#findComment-5208423
    • Do a degree in mechanical engineering specializing in combustion systems and materials. Learn how to actually wrench on things that don't require 70k+ USD buy-in while you're at it. You also want to learn to weld and machine. If you still want to do this then you'll nominally have the knowledge to actually do what you're thinking of doing. Whether you still want to do any of that once you've actually gone through that process is anybody's guess. Personally I cannot imagine anything more frustrating than trying to package a supercharger under the hood of any of these cars when the turbos are already fighting for every last inch.
    • That's a function of the fuel pressure reg, not the pump. The pump can do more, needs to be able to do more. The reg keeps the pressure in the rail constant above whatever the manifold pressure is.
    • You need enough post count to have PMs enabled. It will come. They are not the same. The NA box is the skinny little box and the turbo box is the big heavy one, and the yokes are not interchangeable.
    • So, you're not talking about rebuilding the dampers, just putting new tops on them? You just need new tops and a spanner.
    • Hi All, Does anyone know how or who (shop) could rebuild my original R32 GTR Nismo struts? These are the OG logo ones that were a factory option back in the day. I've replaced them with aftermarket coilovers which are good, but the OG Nizmo struts tha i bought the car with i feel are amazing, just the rubber tops are worn and would need replacing... Plus it would make it 100 time easier for me to get the GTR fully engineered without adjustable coilovers... I was considering selling the OG suspension, but if i can get them rebuild / refurbished, I would seariously put them back on. Cheers, Tom   p.s. I'm in Sydney by the way and don't mind travelling if need be to get these puppies rebuilt.
