  • Replies 45
Sorry, wasnt really thinking :D
Hehe... oh yes you were :P
Can you see it now? Roy becomes SAU agent provocateur?
Double-sting is that Roy comes clean as he explains the ACA furphy to TT > then watch the bunfight! :rofl:
Actually, I like it Roy! :P
Yeah dunc ... Mark machine is getting there now
Still plenty to do including more testing , a gurney flap has been fitted to the rear wing and a new front under tray and mounting
Also some intercom set up for communication, grip is now really different so tyre wear on the front has changed heaps of course.
(on top of fixing my machine for me ! )
And yeah I said the same about the tail light out !!! Lol
Yep fully adjustable on the fly from zero through to lock! But Also fully adjustable seperately for under brakes,
And also a disconnect button on the steering wheel, it works so well the r32 will be converted too but maybe not before superlap
Does that mean you don't have the variable awd system anymore to adjust torque split based on the g sensors etc. ?
Correct.. variation is no longer based on g sensor.
Adjustable via dash knob with read out
Even on the r32 , using a pressure gauge, 4wd is almost constantly at full pressure especially with a holinger and flat shift, so variations are now controlled under brakes to unwind the diff and also prevent braking 4wd load issues and also stop understeer.
You can also use the flat shifter to unload 4wd on gear change for a split second but we have found that isn't needed,
Very similar to m-speed car.
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
    • Do you plan on using 98 or e85?
    • This should be pretty easy. 200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo. These things have like a .48 rear. You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
