From the Targa update feed, aren't these guys in the TOUR, not racing! :)
"From TS10, car 56, Sebastian Lip and Brett David in a 2009 Nissan GT-R 35, had an off 1.7km into the stage. They found the car behind a shed, with some fence damaged ……. Both crew members are okay. "
Quinn cuurently in 3rd, with Jones in 5th.
Steve Glenney doing a great job in the RX8 in 2nd.
https://www.sau.com.au/forums/topic/318577-targa-tasmania-2010/
From the Targa update feed, aren't these guys in the TOUR, not racing! :D
any word? i hope everything is ok.
Good to hear that Sebastian and Brett are OK.
It looks like the weather was wild at Targa today - video here ...
Looks like there have been quite a few cars damaged - video here of some of them :merli: ...
Photos are being posted here of the event ...
http://www.sportcom.com.au/targatasmania/i...1&Itemid=68
Videos are being posted here ...
http://www.sportcom.com.au/targatasmania/i...8&Itemid=61
- The Tuners Group
Edited by TheTunersGroup
wow some shit went down today... nasty nasty. lucky me gets to watch them from my backyard on sunday!! grass tree baby
not sure exactly, someone stacked it, and I think Glenney in the RX8 stopped to check if everyone was okay and another car cleaned everything up but the possums =(
Edited by Mr. Untouchable
no the opposite unfortunately.
Ayresy in his immaculate 400R stopped to help and Wwilfred cleaned him up in the borrowed Rx-8.
Good to see all the R35s staying on the track including domonic from here. Hope I didn't just put the mocker on anyone.
My guys have had mixed luck, Kel is going great in the R32 (or ATTKD special if you prefer) in 9th in Early Modern. Mark is running a wide body gtst since he had to pull the front drive shaft after a diff blow up - nowhere on the board but still having fun.
Ours came close to disappearing a few times.
http://www.flickr.com/photos/90747317@N00/...036746916/show/
Arhhh the hottest R35 getting around! Post up the vid Dom...*giggles*
Hope to see you at another one of our supersprints soon! :) Will gladly take the 35 for a lap or two again for you :D
Are you doing Targa Hi Country???
Great photos Dominic - this photo is epic ...
http://www.flickr.com/photos/90747317@N00/...57624036746916/
- The Tuners Group
Hi Dom, Tim here from the Porsche 944 (#736) we were usually in the que together at the start of stages.
I must say you always had a grin on your face so you must have been enjoying yourself! I always got a great chuckle out of the stickers on your rear bumper!!!
Hope to catch you at more events soon!
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
