hey guys, um recently got a r33 s2 motor and gearbox package to put in my 32!! its now in gearbox in got the custom tailshaft ready to put in :D
um but having a little trouble with the wiring been researching it to try and void payin a auto elect. had a couple mates found this link http://www.skylineowners.com/forum/showthread.php?p=1159026 it shows how to wire up a 25!!! but using the 20 loom and part of the 25 loom and running the 25 computer!!! my mates are wiring it up for now like this but im just not to sure bout it!! if anyone wants to have a look at it or done it this way any feedback would be great cheers
https://www.sau.com.au/forums/topic/318605-rb25det-wiring-into-a-32-gtst/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
