Hi all.
Have any of you heard of a wheel alignment causing a brake vibration?
(R32 GTR)
I never noticed it before I had the wheels aligned.
Does it with two separate sets of wheels.
Only occurs while braking, can even feel it with light modulation at slow speeds.
No perceptable vibrations under other circumstances.
I'm suspecting warped rotors (DBA4000's 324mm F + stock 297mm R) because the car is tracked, but like I said, never noticed it before the alignment.
And didn't do it after previous track outing either.
Any feedback appreciated.
:D
https://www.sau.com.au/forums/topic/318614-brake-vibration/
k wheel alignment should not affect the brakes as the wheels are not taken off to do with an alignment so im not sure y that is there after a wheel alignment unless they drove the car round the blosk and hamered the brakes
https://www.sau.com.au/forums/topic/318614-brake-vibration/#findComment-5206608
    • Awesome mate, sounds like an awesome car! My 33 has the 400R/Nismo front and rear bumpers and side skirts. They're in terrible condition though so I either need to fix them up or toss them and get new, standard bumpers and skirts. I wish the Nismo stuff was FRP not fibreglass as they're always one nudge away from complete destruction!
    • Thanks mate 👍 The car was brought into the UK by a USAF mechanic until he was stationed back to the US, one owner later I bought her back in 2009. Luckily the only corrosion was on the sill seams, so once taken back to metal and treated and sealed all ok, I then undersealed the car myself and check yearly and treat any corrosion which to be honest is zero. She's garaged most of the time and hardly ever driven in the rain, but as you say most are rotten unfortunately, I was lucky in finding her as she was and still is in excellent condition.
    • Stunning car.  Looks amazing!  You're in the UK?  How the hell do you stop your car rotting away beneath you?  British cars are the WORST I've ever seen in regards to rust.  Some of the cars SR Autobody have done are borderbeyond saving.
    • not a date code? or a foundry code?
    • I have up to date pics of the engine build and turbo conversion over on my instagram @skpro_jects if you want to take a deeper look.   Basically the exhaust manifold is straight bolt on and the ports match (they arent any smaller than a 25 or 26 head).    the intake ports are different shape so the 20/25det manifold will bolt up but wont match properly or seal. You will need to port match using the 25det gasket as a stencil. Personally i ran the entire stock 20neo intake setup and have configured the swirl valves and torque valve to work based on my custom parameters to help with off boost response and spool. But this is using a standalone aem v2 ecu. The stock 20det ecu wont be able to control them.
