For sale:
1990 Nissan R32 4 door - Turbo manual
km's: 12x,xxx (have had it since 70,000 and most is highway km's)
The Car used to be Non-Turbo Auto, but is now Turbo Manual...the conversion was done properly and has been very reliable for the last 10,000kms. Most of the time this is just putted around as to me its just a daily As i have a track 180sx as well.
Car doesnt have HICAS at all, and driveline and brakes, 5 stud hubs are all GTST now and the diff is a stock LSD.
RB20DET
5 stud conversion
R32 GTST Brakes + Brake booster
Turbo LSD
Velour Late model seats and trims
Swapped All side glass out (as it was tinted)
3" Cat back exhaust
Manual conversion kit
th_Hawker180_R32cooler.jpgth_Hawker180_R32engine.jpgth_Hawker180_R32Front.jpgth_Hawker180_R32inside.jpgth_Hawker180_R32inside2.jpgth_Hawker180_R32rear.jpgth_Hawker180_R32Side.jpg
The Car:
1990 Nissan R32 GTS
RB20DET (originally RB20DE)
5 speed Manual (originally Auto)
Engine mods:
Stock RB20DET
Stock Turbo (genuine 55,00kms on turbo when i put it on)
GReddy Return flow Intercooler
K&N Panel filter in stock airbox
Spitfire coil packs
3" Cat back Exhaust
Walbro Fuel Pump (Genuine)
Turbo Radiator
Exedy 5 puk clutch
Electronic:
GReddy Profect Boost Controller (not setup, just using it as a guage at the moment) Boost is bleed with a bleed tap (0.9 bar)
Suspension:
KYB Lowered Struts and springs
5 stud conversion - R32
R32 LSD Auto - (originally single wheeler)
R32 GTR rear swaybar front is stock
Exterior:
Rare 4 door Type M Skirts and bibs
Dark tint all around
Tow bar, great for 6x4/motorbike trailer etc...
Interior:
Velour Late model 4 door seats out and trims (originally grand-pa spec) - these are awesome condition!
Skyline floor mats
GTST steering wheel
Blaze gearknob
The bad:
It has 2 large scratch marks from keys (both before i brought it), one on the bonnet and one down the passanger side.
Rear guards need some paint as i rolled them to suit the wider wheels.
Front bumper has scrapes on it
Car currently has Work Meisters on it, would perfer to sell with stock wheels at a cheaper price but could come with the other wheels for extra of course
Price: $8,500 FIRM with stock wheels
$9,500 FIRM with Work Meisters (Black centre 17x8 +30 and 17x9 +30)
No SWAPS, unless you have a BA Ford Ute/Sedan + money
no RWC, Photos are pretty old, can post up some new ones with the nicer seats/steering wheel as well as the current wheels.
Edited by Hawker180
Did you use the original RB20DE or drop another RB20DET in there? Is it registered with VicRoads?
Is the car currently registered? If not when did the rego expire?
What do you reckon is required for RWC?
Cheers
Its is another engine out of a donor skyline I purchased. So a stock RB20DET. New engine numbers and Turbo has properly gone through vicroads as i also did the Brakes etc... It didnt require an engineers certificate.
Still registered (rego expires in a few days, but i will renew it so it will have 12months rego on it)
For RWC im not thinking much, but its hard to day. I reguarly maintain it so i dont expect too much will be needed.
Im going to pull the clutch master off this weekend as it is leaking, so that will be fixed
Edited by Hawker180
Some decent photos, The insides of the car hasent been cleaned yet, so its just AS IS!
A few things i forgot: Brand new battery, Timing belt and water pump done at 117,000kms, clutch only 10,000kms old (Exedy 5 puk)
Edited by Hawker180
  • 2 months later...
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
