For sale:
1990 Nissan R32 4 door - Turbo manual
km's: 12x,xxx (have had it since 70,000 and most is highway km's)
The Car used to be Non-Turbo Auto, but is now Turbo Manual...the conversion was done properly and has been very reliable for the last 10,000kms. Most of the time this is just putted around as to me its just a daily As i have a track 180sx as well.
Car doesnt have HICAS at all, and driveline and brakes, 5 stud hubs are all GTST now and the diff is a stock LSD.
RB20DET
5 stud conversion
R32 GTST Brakes + Brake booster
Turbo LSD
Velour Late model seats and trims
Swapped All side glass out (as it was tinted)
3" Cat back exhaust
Manual conversion kit
th_Hawker180_R32cooler.jpgth_Hawker180_R32engine.jpgth_Hawker180_R32Front.jpgth_Hawker180_R32inside.jpgth_Hawker180_R32inside2.jpgth_Hawker180_R32rear.jpgth_Hawker180_R32Side.jpg
The Car:
1990 Nissan R32 GTS
RB20DET (originally RB20DE)
5 speed Manual (originally Auto)
Engine mods:
Stock RB20DET
Stock Turbo (genuine 55,00kms on turbo when i put it on)
GReddy Return flow Intercooler
K&N Panel filter in stock airbox
Spitfire coil packs
3" Cat back Exhaust
Walbro Fuel Pump (Genuine)
Turbo Radiator
Exedy 5 puk clutch
Electronic:
GReddy Profect Boost Controller (not setup, just using it as a guage at the moment) Boost is bleed with a bleed tap (0.9 bar)
Suspension:
KYB Lowered Struts and springs
5 stud conversion - R32
R32 LSD Auto - (originally single wheeler)
R32 GTR rear swaybar front is stock
Exterior:
Rare 4 door Type M Skirts and bibs
Dark tint all around
Tow bar, great for 6x4/motorbike trailer etc...
Interior:
Velour Late model 4 door seats out and trims (originally grand-pa spec) - these are awesome condition!
Skyline floor mats
GTST steering wheel
Blaze gearknob
The bad:
It has 2 large scratch marks from keys (both before i brought it), one on the bonnet and one down the passanger side.
Rear guards need some paint as i rolled them to suit the wider wheels.
Front bumper has scrapes on it
Car currently has Work Meisters on it, would perfer to sell with stock wheels at a cheaper price but could come with the other wheels for extra of course
Price: $8,500 FIRM with stock wheels
$9,500 FIRM with Work Meisters (Black centre 17x8 +30 and 17x9 +30)
No SWAPS, unless you have a BA Ford Ute/Sedan + money
no RWC, Photos are pretty old, can post up some new ones with the nicer seats/steering wheel as well as the current wheels.
Edited by Hawker180
Did you use the original RB20DE or drop another RB20DET in there? Is it registered with VicRoads?
Is the car currently registered? If not when did the rego expire?
What do you reckon is required for RWC?
Cheers
Its is another engine out of a donor skyline I purchased. So a stock RB20DET. New engine numbers and Turbo has properly gone through vicroads as i also did the Brakes etc... It didnt require an engineers certificate.
Still registered (rego expires in a few days, but i will renew it so it will have 12months rego on it)
For RWC im not thinking much, but its hard to day. I reguarly maintain it so i dont expect too much will be needed.
Im going to pull the clutch master off this weekend as it is leaking, so that will be fixed
Edited by Hawker180
Some decent photos, The insides of the car hasent been cleaned yet, so its just AS IS!
A few things i forgot: Brand new battery, Timing belt and water pump done at 117,000kms, clutch only 10,000kms old (Exedy 5 puk)
Edited by Hawker180
  • 2 months later...
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
