Hi,
My bro just got his new line and we were intrested to see what the turbo looked like to compare to other bros turbo.
and we noticed that the fins look different and are bent and chiped ?
is this a problem ? do we need a new turbo ?
their doesnt seem to to be and problem when driving, all though it sounds different when it spools up you can hardely hear it, it doesnt make the whistling sounds like the pod but its a different sounds ?
Thanks,
by the way its on a 95' gtst
(i'll post pics later tonight)
https://www.sau.com.au/forums/topic/31865-damaged-turbo-wheel-r33-gtst/
Well if you go two turbos off the same series motor.
then you can bet your dollar it's a bit damaged.
chipped is not all that good.
Fins can have a 'bent' look. it might just be the wheel.
I dunno what the differences are between the two though... series I vs II.
but i think there was something a tad different.
either way for a new one you only looking at $400
hi
I think I might be having a problem with my turbo too...
It looks ok the last time I checked it..
but at higher speeds.. about 200km/h + there's a really loud shhhhhhhhhhh sound... quite unnatural...
not sure whether something's wrong with the turbo or the blow off valve...
I'm running on standard turbos and turbosmart BOV..
anyone experienced this before?
thanks
That turbo has ingested something, but if it still goes, then keep using it, unless you really want to upgrade. These turbos are generally, not very servicable or rebiuldable. But they are quite tuff. It could keep working fine for years to come. Look at it this way, you only found the damage, coz you looked....you didnt hear any strange noises or see oil or anything.
You can if you want, buy a new comp wheel and get it fitted and balanced, but Personally I woudlnt bother, the time and money isnt worth the problem if the wheel fails. I doubt you would notice the drop in power at all.
I have been playing (that should read, trying to fix:P) a couple of rb25det turbos, and have found the following info....
If you break the seal plate, you can't get a new one (oh no!) If you own a lathe, you can make a new one (doing that now actually)
The turbine is not able to be serperated from the shaft, and is balanced as a single unit
The comp wheel is balance as a single unit, and therefore, you can generally swap wheels with not too much hassle (if you dont balance them, you will get a shorter turbo life, but generally, you will get away with it)
IF you pull apart totally the bearings, (they are not captive bearings) the balls will fall out and roll across the floor, into the drain, cracks in the concrete etc etc, bye bye turbo....
If you can feel shaft play sideways or end ways, the bearings are worn, but if your lucky, you can still have some more room to tap in the centre peice of the comp wheel side bearing (under that damn seal plate im afraid, hard to take them out without breaking them) and get rid of that play, and get another 100 000 kays out of a unit.
Worn bearings and side play and end play in the shaft leads to misalignment of the seals, which of course leads to oil leaks, smoke, etc....
by the way, I picked up a second hand turbo for $200 on the weekend and fitted it to my twin turbo rb25dett VL and it fixed my problem.
So as you can see, spending money at a turbo shop rebiulding a stock rb25det turbo is not a financially rewarding thing to do. Its better to just source a second hand one.
I had two good turbos, untill one started leaking oil into the air intake. Upon trying to fix that turbo, i broke the seal plate. Bought a buggered turbo for $70 and broke the seal plate in that trying to get it out too! :P (DOH)
Bought another good turbo for $200 and fitted it and no worries.
Now im making two new seal plates, using two new o rings, and setting up the bearings in those two turbos again, to see if i can get those turbos operational again. If not, ill turf them:P
black smoke is fuel not oil.
why should it boost higher than standard boost? you got a bleed valve hooked up?
If you have and its refusing to boost very high, it could be any number of alot of other things. I've never seen a turbo that is in such a state that it wont boost higher than standard boost, unless its really stuffed (turbine hitting houseing, seized bearings, etc)
They seem to either work fine, or dont.
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
