For Sale is 1997 Autech s15
Reason for sale is that I upgraded to somnething newer and better and no longer need two cars.(was going to keep as a daily but sadly it does not get driven and sitting around is a waste of a good car.)
Have recently serviced about 2000 kms ago and replaced spark plugs and fuel filter along with oil change and filter.
Runs fine with no problems at all, and as those who have owned autechs before know has a fair bit of go for a na motor.
Have owned it for under a year and have had no issues and has been looked after
SR20DE 2.0 litre 4 cylinder Autech motor (147kW)
approx 136 kms on speedo
2cnd owner in Australia (was imported through Iron Chef in Nov 08
Full URAS bodykit
6 speed manual
Pearl White
ORC Clutch
Privacy glass at rear windscreen and rear quarters
Advan RGs, 16's at front and 17's at rears
Kakimoto exhaust
Double Din CD Player + pioneer 12"sub and amp
HKS Hypermaxx adjustable coilovers
Headers
Toe arms
Auction grade 4B
Strut Brace
1.5 LSD
Aircon works
Airbags
THE BAD!!!
Unfortunaetly the front bar has had a bit of wear and tear and will need some touching up or replacing and the rear bar has a small crack or two..(my old bar got replaced with a newer second hand one which had been previously damaged, but a fox managed to make a mess of it not long after replacing it and some curbs have left their mark on the bottom as many low bars have. Otherwise the car is pretty straight, couple very minor scratches from the previous owner but thats it. interior is clean and tidy, also rear tyres will soon need replacing
was Looking for $16,500
as people know p plater laws are set to come into SA around June from what Iv been told so would be a good car for p platers as they can still drive Autechs, or interstate they are legal for them too.
best to contact via mobile thanks 0419837474
inspections welcome
Located in Adelaide Hills SA 45 mins from city tollgate
Bump to the top
Offers??
Even conversion to turbs motor this is a cheap s15. Wanta see this gone soon,open to offers...need the cash for my new car..
Okay guys,need this car gone-hopefully by the weekend--make me an offer I can't refuse! Throw anything at me!come n look or drive. Legit sale..
Sale just fell through due to the guy not bein able to get the cash together so make an offer
Bump. This has to go
Seems most interest iv had is from nsw-for interest sake I had a gtr freighted from Townsville to my doorstep and that costed 1100$, but I mate had something sent from nsw and he paid around 500$ in freight...
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
