Aussie R31 Front Sway Bar
For all those using this R31 front sway bar.
Have you checked the diameter with a vernier?
Is it for sure 25mm or is it 23mm maybe??
As I have, what is supposed to have come from an R31 Skyline (mind you I didn't take it off myself) and the verniers say it's only 23mm & 24mm bushes are loose & 25mm are very sloppy.
Can someone confirm the diameter of the front Aussie R31 sedan sway bar??? Not the GTS as that was/is 27mm.
Cheers, D
Is it possible the R31 Pintara had an 23mm front sway bar??
And if I can get 23mm GP poly bushes, it still might be a good mix with my custom (Jenesis style) 20mm rear bar. As it's actually shorter than standard, it would be stiffer than standard at the same diameter.
Cheers, D
Cheers, D
Hi Dennis,
just measured it at 25mm.
John
Cheers, D
D,
When I was buying bushes for mine, (SupaPro) they listed 3 bushing sizes 23,25,27mm I assume that the 27mm would be aftermarket bars, but 23 and 25 probably standard depending on year or body type or maybe whether it is a GTS or something...
Cheers,
D :cool:
I just googled SuperPro to check my mameries were right and found their online Catalogue...
It is good, because you can search for the part for your car (LHS of screen), and then switch from 'Instructions' to 'Vehicle Details' (RHS of screen) and find what other cars you might scab parts off...
http://203.31.191.243/fulcrumCat/
Cheers,
Daewoo
Edited by Daewoo
Got my hands on a manual overnight.
Thanks for the info guys, but I know what is the go now.
23mm ~ CA20E R31 Pintara 25mm ~ RB30E R31 Skyline & 27mm ~ RB30E GTS I & II Skyline
I guess the cockheads at the local wrecker doesn't know there is a diference between Pintara & Skyline front sway bars.
Some time back I had a rear bar bent up & asked a member of this forum to trial it, which never happened. It's the same shape as the Jenesis rear bars (minus the kink) in 20mm solid, so I think I will do my own trials wityh the 23mm front & custom shortened 20mm rear. Should work out pretty good for a road car.
Anyway, thanks again for your help,
Cheers, D
Cheers, D
What size front will you use for yor race car? white line do a 27mm adjustiable for the R31 should be an ideal bar for an r30 race application ?? its 2mm thicker than used on the gibson cars but in saying that its adjustiable meaning the soft setting may just be about spot on
If I get it to Adelaide, it's going to have stock shaped 27mm front & 24mm rear, but I'll take an R31/RB30 25mm bar with me, with bushes to suit for trial purposes. It also has 400lb/in front springs & 300lb/in rear springs over the 4 way adjustable JIC Coilovers. I hope to have a set of Toyo R888's for it as well.
Might be fun with about 400HP at the wheels.
Cheers, D
I'll have some pics of my PNV front set up shortly, complete with externally adjustable Koni strut inserts, Cusco camber tops (compliments of the DR) & lowered King springs, SWR adjustable caster bars, new lower control arms, new slotted DR brake rotors, EBC Green Stuff pads & 23mm front sway bar.
I have Reds & Greens for replacement, but for a street car, I think my choice for rear pads will be Bendix General C/T in future and use the reds up front.
Cheers & thanks, D
Very interesting D, keep us posted on how it goes,
my set up will be the whiteline bar adjustiable 27mm, tien s13 coilovers with r32 gtr brakes 350lb springs and adjustiable caster rods... for the rear though im going to down a different track and run no rear swaybar and re valved r33 front coilovers in the rear.. yes they fit and are good with short 250lb rear springs..
the rear end i think will be to stiff with stiff shocks and springs, power to the road is key i noticed the gibson cars ran no swaybars..
Marc
Marc
Marc,
It is my opinion that the Gibson car that Cazz has, that you have been looking at, doesn't have a rear sway bar because the roll cage is welded into the body (which you don't have) and therefore the body has zero give. Cazz doesn't know the spring rates, as I have asked that question.
I can always take it out (the rear) as a test, but I think our cars, without the rigidity of the last Gibson car, will need some rear sway control.
JMHO of coarse!
Unfortunately, I wont have the time to put poly bushes in the rear cross member of the DR, or get them into the moustache bar, so I will be testing with rubber bushes as well.
A mate of mine's son is running an 200B sedan in Club Class with 700lb/in front & 550lb/in rear springs, along with an A bar to control the tramp, plus a panhard rod setup, plus a sway bar to boot, so I don't think spring rates have a lot to do with it.
A question for you. Is this all going into a road car of yours, or the race car in NZ?
Cheers, D
Marc,
JMHO of coarse!
Cheers, D
road car here mate.. and im aware that cazzs car has the body mounted cage and mch extra body work.
but look around the curcits.. not at dad and daves back yard racers.. But proper race cars. many rear drive cars run soft rear ends. but again im not even begining to pretend i know what im on about but im going to try it out.. that and with the factory bar .. my car has eurathane through out but id prefer rubber i think..
Marc
im aware its hard core for road but i dont care
 Share
