For all those using this R31 front sway bar.
Have you checked the diameter with a vernier?
Is it for sure 25mm or is it 23mm maybe??
As I have, what is supposed to have come from an R31 Skyline (mind you I didn't take it off myself) and the verniers say it's only 23mm & 24mm bushes are loose & 25mm are very sloppy.
Can someone confirm the diameter of the front Aussie R31 sedan sway bar??? Not the GTS as that was/is 27mm.
Cheers, D
https://www.sau.com.au/forums/topic/318696-aussie-r31-front-sway-bar/
Is it possible the R31 Pintara had an 23mm front sway bar??
And if I can get 23mm GP poly bushes, it still might be a good mix with my custom (Jenesis style) 20mm rear bar. As it's actually shorter than standard, it would be stiffer than standard at the same diameter.
Cheers, D
Cheers, D
D,
When I was buying bushes for mine, (SupaPro) they listed 3 bushing sizes 23,25,27mm I assume that the 27mm would be aftermarket bars, but 23 and 25 probably standard depending on year or body type or maybe whether it is a GTS or something...
Cheers,
D :cool:
I just googled SuperPro to check my mameries were right and found their online Catalogue...
It is good, because you can search for the part for your car (LHS of screen), and then switch from 'Instructions' to 'Vehicle Details' (RHS of screen) and find what other cars you might scab parts off...
http://203.31.191.243/fulcrumCat/
Cheers,
Daewoo
Edited by Daewoo
Got my hands on a manual overnight.
Thanks for the info guys, but I know what is the go now.
23mm ~ CA20E R31 Pintara 25mm ~ RB30E R31 Skyline & 27mm ~ RB30E GTS I & II Skyline
I guess the cockheads at the local wrecker doesn't know there is a diference between Pintara & Skyline front sway bars.
Some time back I had a rear bar bent up & asked a member of this forum to trial it, which never happened. It's the same shape as the Jenesis rear bars (minus the kink) in 20mm solid, so I think I will do my own trials wityh the 23mm front & custom shortened 20mm rear. Should work out pretty good for a road car.
Anyway, thanks again for your help,
Cheers, D
Cheers, D
What size front will you use for yor race car? white line do a 27mm adjustiable for the R31 should be an ideal bar for an r30 race application ?? its 2mm thicker than used on the gibson cars but in saying that its adjustiable meaning the soft setting may just be about spot on
If I get it to Adelaide, it's going to have stock shaped 27mm front & 24mm rear, but I'll take an R31/RB30 25mm bar with me, with bushes to suit for trial purposes. It also has 400lb/in front springs & 300lb/in rear springs over the 4 way adjustable JIC Coilovers. I hope to have a set of Toyo R888's for it as well.
Might be fun with about 400HP at the wheels.
Cheers, D
I'll have some pics of my PNV front set up shortly, complete with externally adjustable Koni strut inserts, Cusco camber tops (compliments of the DR) & lowered King springs, SWR adjustable caster bars, new lower control arms, new slotted DR brake rotors, EBC Green Stuff pads & 23mm front sway bar.
I have Reds & Greens for replacement, but for a street car, I think my choice for rear pads will be Bendix General C/T in future and use the reds up front.
Cheers & thanks, D
Very interesting D, keep us posted on how it goes,
my set up will be the whiteline bar adjustiable 27mm, tien s13 coilovers with r32 gtr brakes 350lb springs and adjustiable caster rods... for the rear though im going to down a different track and run no rear swaybar and re valved r33 front coilovers in the rear.. yes they fit and are good with short 250lb rear springs..
the rear end i think will be to stiff with stiff shocks and springs, power to the road is key i noticed the gibson cars ran no swaybars..
Marc
Marc
Marc,
It is my opinion that the Gibson car that Cazz has, that you have been looking at, doesn't have a rear sway bar because the roll cage is welded into the body (which you don't have) and therefore the body has zero give. Cazz doesn't know the spring rates, as I have asked that question.
I can always take it out (the rear) as a test, but I think our cars, without the rigidity of the last Gibson car, will need some rear sway control.
JMHO of coarse!
Unfortunately, I wont have the time to put poly bushes in the rear cross member of the DR, or get them into the moustache bar, so I will be testing with rubber bushes as well.
A mate of mine's son is running an 200B sedan in Club Class with 700lb/in front & 550lb/in rear springs, along with an A bar to control the tramp, plus a panhard rod setup, plus a sway bar to boot, so I don't think spring rates have a lot to do with it.
A question for you. Is this all going into a road car of yours, or the race car in NZ?
Cheers, D
Marc,
JMHO of coarse!
Cheers, D
road car here mate.. and im aware that cazzs car has the body mounted cage and mch extra body work.
but look around the curcits.. not at dad and daves back yard racers.. But proper race cars. many rear drive cars run soft rear ends. but again im not even begining to pretend i know what im on about but im going to try it out.. that and with the factory bar .. my car has eurathane through out but id prefer rubber i think..
Marc
im aware its hard core for road but i dont care
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
