Tell me about it - tools are bloody expensive. Think I paid $40-50 for a sutton 1/8 bspt tap the other day.
Can't wait to get my hands on a lathe - more dead ends today trying to find various things if I add up all the time it takes searching I should have bought one a long time ago. Could be a worry though - rather than running around trying to find cheap fittings I will be running around trying to find expensive tools instead.
Excuse the newbie question as I have never actually used a lathe - but I am interested in how you guys go about tapping internal taper threads like NPT & BSPT? I guess with CNC you can program the rate that it pushes the tap into the hole and when to stop, otherwise manually just a slow speed, skill in winding the tool in and a hand on the stop button?
On a CNC Lathe you can program a tapping cycle with depths and feed rates (rigid tapping cycle) will auto feed the tap into a depth and stop.. reverse spindle and tap..
this is based on CNC only.. not a bed lathe with manual controls..
i am a fitter and turner but work 99% on plastics.. and some light alloy.. really fun and interesting to program and in turn make some of the parts..
  • 1 month later...
i remember going to the manufacturing expo in melbourne during my apprenticeship a few years ago. everything was cnc. plasma cutters, mills, drills, lathes, HPW cutters, anything that did anything was cnc... and it was all way over my head. im a maintenance fitter, but i like to mess around with my own projects in my free time.
i only know how to use manual machinery, though ive had some very good results with them. i learnt on old colchesters, they didnt even have a DRO, but thats what im comfortable on now. ive used a heap of diferent lathes, including cheapo chinese models, and ive always found the colchester to be quite capable and definaetly my favourite, while the chinese were my least favourite.
only thing is theyre belt driven, so you cant put a massive cut on. but ive done up to 4mm without any slippage.
im currently looking at second hand quality stuff as im not so keen on the cheaper asian units.
  • 4 weeks later...
we have a chinese copy colchester at work... even its not a real good lathe. I wouldnt recommend it, although I can take a good 7mm cut on mild steel and its belt drivin :)
I use my lathe nearly every day, so easy to whip up a part for a mod, machine my disks, cut threads etc. I don't know how I lived without one for so long. :)
I just finished turning up a petrol priming injector for cold start with e85.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
