Tell me about it - tools are bloody expensive. Think I paid $40-50 for a sutton 1/8 bspt tap the other day.
Can't wait to get my hands on a lathe - more dead ends today trying to find various things if I add up all the time it takes searching I should have bought one a long time ago. Could be a worry though - rather than running around trying to find cheap fittings I will be running around trying to find expensive tools instead.
Excuse the newbie question as I have never actually used a lathe - but I am interested in how you guys go about tapping internal taper threads like NPT & BSPT? I guess with CNC you can program the rate that it pushes the tap into the hole and when to stop, otherwise manually just a slow speed, skill in winding the tool in and a hand on the stop button?
On a CNC Lathe you can program a tapping cycle with depths and feed rates (rigid tapping cycle) will auto feed the tap into a depth and stop.. reverse spindle and tap..
this is based on CNC only.. not a bed lathe with manual controls..
i am a fitter and turner but work 99% on plastics.. and some light alloy.. really fun and interesting to program and in turn make some of the parts..
  • 1 month later...
i remember going to the manufacturing expo in melbourne during my apprenticeship a few years ago. everything was cnc. plasma cutters, mills, drills, lathes, HPW cutters, anything that did anything was cnc... and it was all way over my head. im a maintenance fitter, but i like to mess around with my own projects in my free time.
i only know how to use manual machinery, though ive had some very good results with them. i learnt on old colchesters, they didnt even have a DRO, but thats what im comfortable on now. ive used a heap of diferent lathes, including cheapo chinese models, and ive always found the colchester to be quite capable and definaetly my favourite, while the chinese were my least favourite.
only thing is theyre belt driven, so you cant put a massive cut on. but ive done up to 4mm without any slippage.
im currently looking at second hand quality stuff as im not so keen on the cheaper asian units.
  • 4 weeks later...
we have a chinese copy colchester at work... even its not a real good lathe. I wouldnt recommend it, although I can take a good 7mm cut on mild steel and its belt drivin :)
I use my lathe nearly every day, so easy to whip up a part for a mod, machine my disks, cut threads etc. I don't know how I lived without one for so long. :)
I just finished turning up a petrol priming injector for cold start with e85.
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. 😭
    • If you don't touch the CAS, then you're fine.
