on swaybars....actually for anyone new at the track....
most important thing (apart from learning how to drive around the track) is to get your tyre pressures right first.
frist thing decide target tyre pressure. If you don't have a specific number try 38 for road tyres, 34 for semi slicks.
It's wakie and its winter...so start with the following cold tyre pressures:
RF target -6
LF target -8
RR target -6
LR target -4
don't worry too much about the first session, just feel your way around the track.
second session give it a warm up lap then 3 hard laps, then come into the pits pretty quick (let the brakes cool a little but don't back off on the tyres). come into pit lane, pull to the side, leave the car running/out of gear/handbrake off.
let the tyre pressures in each tyre down to the target pressure.
then go out and enjoy the day!
Once the tyre pressures are right, if you have adjustable bars set them both to medium. if you get too much understeer back off the rear bar to soft. if you get too much oversteer....maybe try softer front bar, or more front torque if its adjustable, or turn in later, or more progressive throttle out of the corner. If it rolls too much go harder on the front bar. but basically change them from session to session (pretty easy) and see what you like :bunny:
Remember each 3 hole bar has 5 settings because you do not have to adjust them evenly (ie you can have "hard" on one side and "medium" on the other to create "medium/hard")...so there are plenty of settings to confuse you!
hope you got the wheels aligned before you went to the track!
  • Replies 566
nah all good bobby, 8 year old ACL rupture that ive been putting off but know its giving me grief all the time so biting the bullet.
about the car, if you guys are serious about running it im happy too have it ready as i want to test the new sump. have already asked Ando but he reckons he might be too busy.....scared lol.
PM me and let me know. Besides i want to hear it from track-side.
Bring all your tools, and any spare parts you may have.
Bring spare coolant, oil, brake fluid, power steering fluid etc.
You will much rather have it, and not need it, then need it, and not have it...
Ill be bringing my big trolley jack, might bring a few peices of wood for u very low ppl.. trolley jack is 70mm when lowered..
Full Name: Reece McIntosh
Car Type: Clio
Newb or not: Rookie....
Most recent lap time if not newb (can be another track if necessary but make sure you mention which one): 1.11
# of Drivers: 1
# of Passengers & Name: TBA
I left it late, but I will be there :bunny:
yayyy Reece!
and OMG....8 years and Shell enters a track day! You'll have a ball :bunny:
haha it's the first time I've had a "spare" car (even if its a stockers POS) so I don't have to worry about how I'm getting to work on Monday if anything breaks!!
orly? Never considered that! Thanks Druncan :D
same...happy to take it for a spin stu!
dave, don't worry there will be plenty of tools there on the day...haven't you met the exec committee :thumbsup:
and OMG....8 years and Shell enters a track day! You'll have a ball :rofl:
See what fresh blood on the commitee does? We get everyone involved!
Car Type: Clio
# of Drivers: 1
I left it late, but I will be there :thumbsup:
about time!!!
Pfft, wouldn't matter what you use, Reece... You could probably put us all to shame while you're riding a Big Wheel - who's old enough to remember those, btw???
Looks like I will only be coming as an "assistant" at this stage. I could get the car going in time but it won't be quite right... and experience tells me that the only outcome from "not quite right" is disapointing and usually quite expensive. So I have decided to leave the girl parked in the garage, where she can't break anything :blush:
I am hopefully still going to come down and if I do am happy to help out where ever I can be used. Last time I had a lot of fun at pit exit ensuring that Neil and JP happened to find themselves rubbing elbows for the same peice of real estate. :) Although this didn't help me find my way out onto said real estate even if in the passengers seat. :)
Passengers can go into other cars, however I'm pretty sure there are quite strict rules about camera equipment inside cars.
Last i checked, a photog holding a camera and shooting while someone is driving, was not allowed.
Ando, correct?
    • So where is this message group so we can organise another meet? Keen to come along and catchup. Might eventually be in a skyline again next year, but the Mustang will have to do for now. Also need to get the WRX back on the road. Stupid f**king money pit that thing is.
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
