Full Name: Jeremy Coe (username JMKC)
Car Type: z4 m coupe
Newb or not: not..
Most recent lap time if not newb (can be another track if necessary but make sure you mention which one):1.16ish
# of Drivers: 1
# of Passengers & Name: tba
money transferred.
  • Replies 566
Hey Doobs,
Do you own the slick black R33 GTST? Yeah I own the gunmetal grey R32 GTR V-spec with the proper (poxy) BBS alloys. Sorry I haven't replied direct to your message but I haven't got up 10 posts yet... also I'm a bit computer illiterate! Hope to see you at the track on the 17th.
Cheers, Ben
Full Name: Matt Cass
Car Type: Hopefully a R33 GTS-t
Newb or not: Epic newb
Most recent lap time if not newb (can be another track if necessary but make sure you mention which one): NFI, around the 1'14" mark I guess... I really need to get to a timed day lol
# of Drivers: 1
# of Passengers & Name: Zero ATM, may drag someone along :P
Full Name: mark joung
Car Type: 370z
Newb or not: newb
Most recent lap time: 1:15.5
# of Drivers: 1
# of Passengers & Name: 0
$200 payment sent! looking forward to meeting you guys
370z!!!!!!! Omg if you see me quietly fapping over your car please excuse me....... i can't wait to see one of these on the track!
Glad you're on board Mark and come say hi!!!! Well i might actually come say hi to you, and perhaps hop in for a passenger session :(
don't put the handbrake on when you park it after a session :blush: don't want cooked brake fluid.
Having the handbrake on after a session on the track won't be the thing that boils your brake fluid. It may very well fuse your handbrakes to your rotor and/or warp said rotor though :blush:
Best option is to put a choc under a wheel, that way you can't hurt anything that has warmed up...
Yep, and when choosing a choc, those huge Toblerones are the correct size and shape!
:blush::blush:
Best option by far is what Dan just said.....
Just bring along a couple bits of small timber with you and lay they down in your car spot, 1 at the back to roll up against and 1 at the front to roll over and keep you in position. This way you can leave the car in neutral, no brakes at all and let it cool down/leave running for 5 minutes after a session.
Also a big tip, on the cool down lap (in lap), don't go slow!!! 1 reason is it slows up the next session getting out BUT most importantly you need to maintain a safe speed to feed cool air into the engine bay, brakes ect etc to cool it down. So don't back right off! Helps reduce heat soak :blush:
Old sports socks over all reservoirs is also a bonza trick!! Just make sure it is secured by a cable tie or very tightly wrapped around it!!
Hey Doobs,
Cheers, Ben
Yeah that's the one. I might come down to watch as the car isn't quite reassembled for track work yet.
The garages at Wakey are pretty flat anyway, I find my car sits pretty sweet without leaving it in gear or with the handbrake up. Chocs can't hurt for an extra bit of insurance though :blush:
Full Name: Alex King
Car Type: Evo VIII
Newb or not: not
Most recent lap time: 1:08.5 (Over 12 Months Ago - Have not tracked for a while)
# of Drivers: 1
# of Passengers & Name: 1 - Stephen King
$220 payment sent! looking forward to meeting you guys
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
