Sau:nsw Official Wakefield Trackday 2010 - Full
S13Deviat
  • Replies 566
Updated list
Sellers:
Aggroman --> Sold to Mccready
GTRsean --> Sold to Ravenoak
Tonba --> Sold to a mate (please let me know details)
Black Beast has spot for sale - Deano1 to buy
Liz has spot for sale - Sell to myr332!?!?!?!?
Potential Buyers:
Deano1 - taking Black Beast spot
myr332
So looking at this, Liz is only one left with a spot for sale. So hopefully this can go to myr332.
LIZ - Can you please chime in or PM me and/or myr332 pretty please :D
ando, where did tonba say he was pulling out? i cant see any of his posts that say anything but showing up?
Liz we are full so we can do a refund. send me your mailing address and I'll organise a cheque. unless someone takes your spot first
Duncan, i think Liz has/should be selling position to myr332. If not resolved by tomorrow then refund Liz fo shiz!!
So we may be down to 46 entrants which is still A OK!!!
Titan - Alex has PM'd and also mentioned on JDMST that he is a no go for the day :whistling: But he still needs to tell me the name of his replacement :teehee:
Dont forget wakefield now has complete LED ...
filthy ricers!
you mean the triumph? thats british, so reece's car will just surrender if it trys anything, being french and all. :blink:
I understand Reece's car also has 5 reverse gears and 1 forward, just like their tanks.
You're about as decisive as a nanny undie shopping!!! Hilarious :blink:
I will take you off reserves list now!!
And you know the funny thing... A mate has just called back (6:30am is a little early in my book, but at least he called, lol) and said he will come over and help me put it all back together tonight after work... he didn't even flinch when I said I was down in my garage until 1am this morning and when I came up the thermometer read a toasty -3 degrees!!! (I had no chioce but to put the tools down as my hands had become numb even through my gloves :D)
Problem is if I do get it all together tonight I have to somehow get it to the tuner tomorrow if it is even at all possible for him to tune it.
I really wish I could have made this one... :D
Dan.
My old man will be there in zeeee german beast, safe to say he will be the only Audi there..... :blink:
l will be there in my Triumph tr8.. the small but loud red beast. Being British however it will probably be the one with electrical problems;-)
Can I please be put on the reserves list?
Full Name: Mark Guyer
Car Type: R32 GTR
Newb or not: NOT
Most recent lap time if not newb (Wakefield): 1:07
# of Drivers: 1
# of Passengers & Name: 0
I will pay as soon as its confirmed I can run and/or cash on the day.
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
