********** UPDATED WITH RESERVES LIST 06/07/10 ************
Okay, obviously there are a few people who missed out on getting a spot in the initial 48 :banana:
Thus as mentioned previously, I have posted up a reserves list (1st post in this thread)
For any unfortunate drivers whom for whatever reason can not make it to the day, can sell their position to a person listed on the reserves list. The price is at the sellers discretion and not moderated by SAU:NSW.
Please let me know of any changes so i can update our list accordingly. If you have any difficulty contacting a member on the reserves list, just let us know and even post here your desire to sell your spot.
Any issues, queries, drop me a line :)
PS. I will have the groupings/new thread up hopefully tonight!!!
Excited! You better be, only 10 sleeps to go ladies n gents :P
  • Replies 566
Everybody be sure to check out the details thread over here http://www.skylinesaustralia.com/forums/Sa...ps-t327842.html.
Details for the day and now exciting news about the photography package on offer on the day.
Go check it out!
Please add me to the reserves list. :cool:
Will do
Can someone please put Bec onto the passenger list, I've paid Shell for Membership tonight.
Thanks.
Will do
If there are any late drop outs I am happy to take a spot. Bit late I know but the day has now been freed up on my calendar.
cheers
Will add you onto reserves list
Mr.V
please add a passenger for me, paid in full. Cheers
#Drivers-1 (Mr.V)
#Passengers-1 (Mick Williams)
Will do
:D
Try Dan (majanal) & ravenoak as well!!!!
What ever transpires with selling of spots please PM or let me know so i can update the list!!
So far i see 3 entrants selling their spots, Aggroman, Black Beast & Liz.
There are at least 4-5 people wanting a spot.
Any issues, let me know!
Guest
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
