Probably be something like the 25 turbo was on my 30.. 12psi by 2200rpm! lol
Yep id be happy with that!!!
How was it in the top end?
Its so frustrating trying to get the "perfect" set up. I want to get mine coming on about 1500rpm sooner, so i think changing cams is the go. Makes 400rwkw at 5000rpm now.
Id hate to be chasing something like a 180sx with a 3L and a super responsive turbo through hills though, there's just no chance of catching something like that haha
i dont think cams will get you 1500rpm when .5L only gets you 1000rpm sooner.
i currently have a stock 25 turbo on mine, great fun at street speeds though its dissapointing over 3k and horrid over 5k
is that with a aftermarket computer or the standard one? wouldnt mind getting mine going on the standard one for the moment then putting the aftermarket one in abit later. can do it all now/whenever i want if i really want but would love to get it running again without spending all my money on it.
has anyone used the standard ecu on their rb25-30? sorta worried about doing that coz it might be in the rich maps and wont allow the new motor to bed in properly from running rich. piston rings and glazing the bores and crap like that
aftermarket ECU my RB30 has had an aftermarket ecu since it was installed never used the stocker on it. Its still running the GT35R tune too and runs surprisingly well, no knock issues and the mixtures are good. Havent had to touch it at all, except when it blew a cooler pipe off and was running on 4 cyls, still drove ok like that though go map sensor ecus :P
Imagine something like a 3071 on a 3L. Fkn hell that would be fun
i think a 3071 would be seriously borderline for exhaust turbine flow @ 7500-8000rpm. the 3076 makes a great combo boost starts properly building at 1500 and takes off at 2500 (thats a friends supra (3076 0.82 rear/6boost mani/44mm external gate) but an RB would be similar). maybe you should go something like that on yours steve? it hauls ass out of corners and is so smooth in its power delivery.
Well there's mixed views on which cams for what rpm band etc
Only one way to find out though :P
It would be nice for response and hillclimbs, but i cant go backwards in power. It just feels so good right now, im finding the happy balance between power and response
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
