.63 or .82 gt3071 with e85 and plenty of boost should come about as close as your gonna get to your goal.
or if your happy to go crazy with boost (and not worried about turbo life and heat etc) you could try a large rear housed gtx28 of some sort
I did actually have teh GTX28's in mind for the 1J, cant help but think the turbine side will be too small for the 3L
But I am now looking at those options, Cheers
Fuel economy and E85 dont mix :)
I did 180kms on the weekend and used 40L lol
Ive done 280ks to 40oddL of 98 and the car is standard lol
  • 2 months later...
  • 3 weeks later...
I have no updates. But 3.0L related
Has anyone seen either a td06-20g or any other smallish turbo on a twincam 30? I have seen a few gt3076's done
Or if you had a choice the best super responsive circa 300rwkw turbo
I'm thinking I want 20+ psi at 3000 rpm and mega midrange
I'm planning on slapping together a 25/30 for round 2 on the 14th of July and i'll be running a TD06-20g High mount.....
I shall inform you of how it goes!
You can use this one:
http://justjap.com/store/product.php?productid=17872&cat=&page=1
But ideally you want one a tiny bit shorter as once you deck the head and block and the belt stretches a bit it gets real close....
Much better off relocating the drivers side tensioner, just wait until you have a belt so you can figure out exactly where to put it as the dimensions in the PDF don't always work.
I used the measurements in the PDF with the above belt and it didnt work, couldn't get the belt on but it was close. Probably just needs to be moved to the right 5-10mm. No set measurements are garunteed to be perfect as theres too many variables.
here is what i do at work;
i grind the head & block
i put the cams in
i put the crank in
i put a thick rag on the deck
i put the head on
i put on all the timing gear
i put bearing blue on bottom of stud,
i then line up tensioner to where its best suited
i then drill and tap the M10x 1.5 thread
  • 1 month later...
Started getting things together to get my dirty thirty project started. Funds are an issue for me so may take longer than u guys lol. But I don't wanna take short cuts so a bit longer without will be worth the wait. Picked up a complete rb30 out of an r31 couple weeks ago for a hundred bucks and a case. Planning on getting an engine stand soon and stripping it down. Then finding a r33 25 head as I want it built out of car to be slotted into daily when complete. So much info! Been reading for the past 2 weeks and printing shit off. Gerg, looking at bringing block, head and other bits and pieces down down to you if ur in Moorebank cause its around the corner from me. A while off though lol.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
