Actually the original form of the GT2860RS was with the 0.86 A/R turbine housing . Many at Garrett in the US reckoned that if it didn't have the larger ratio turbine housing it wasn't a real DP turbo . They also said that HKS was silly not to have had a 0.86 A/R turbine housing available for the GT2530 .
Anyhow like most things in the GT25/GT28 families the hard bit is finding a T3 flanged turbine housing to make them bolt onto RB exhaust manifolds . HKS have them in 0.64 A/R and Garrett don't do any T3 flanged housings for them at all .
A .
Yes that is correct, Garrett don't make any T3 housings for them but both Sonic and AVO do. The sonic housings are a cleaner casting though.
Have bolted a couple of these on to RB20's now so no comparison of response can be made against a 25 but I can tell you now that when the power curve from the Disco was overlayed against the factory turbo, they run on top of each other until the disco starts shooting up over the top of it when the 20 turbo runs out of puff.
Roughly $1900 for the disco with a Sonic housing, water and oil line kit, adaptors and new studs all over. It even matches the power output of a highflow but has the response of a factory turbo.
EDIT: The Sonic housings are 0.73 also
  • Replies 46
how far do they run ontop of eachother? i would hope an upgrade turbo would be far superior, not slightly.
its hardly worth the outlay if until 5000rpm its as good as stock and from 5 up its making more power. one would hope that there is a significant gain from the point where power comes in and up, not just from where the stock turbo falls over.
Hey guys
cheers for all the info good to see everyone putting the bit in:) i've got a bit to think about then, i'll speak to Stao.
A bit off topic but i've just measured my cams out of my neo and i have
Inlet 86mm
exhaust 82mm
That means they are gtr cams, why would they do that? obvoiusly better performance!
Standard neo are
inlet 84mm
exhaust 87mm
Just wondering if i replace the original cams in the second hand motor im going to put in, with the gtr cams and disconnect the vct is that all i have to do to make it work?
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
