Hi all, has anyone dealth with Southern Special Vehicles? They are importer for Nissan cars but they also do a small volume of other makes. Just want to get some feedback on them as you know some importers are dodgy. I am interested in a V35 they have there.
Appreciate all comments. Cheers
https://www.sau.com.au/forums/topic/318806-southern-special-vehicles/
I looked at a Supra there before I got the 32, nice blokes, let me test drive etc, had a knock in th esteering apart from that it was good condition, they also get in 260RS Stags every now and then. I've heard no bad stories about them yet. They bring in a lot of JDM vans and evos
I think if you do a search, you will find some feedbacks of a few importers around Melbourne :rofl:
There has been a fair few threads about it.
As Charles says, do a search, at least a couple of threads on this. Good wrap.
I bought my very first car there R33 S1 did not miss a beat, if i had a problem they would do everything possible to make it right,traded it in and ordered my stagea from japan through them not a single drama as far as cost etc and the car is sweet, i cant recommend them enough
Thanks for the replies guys...
I found them to be quite trustworthy too. But they only take about 1k off their advertised price though. Did you guys manage to haggle much at all?
I got about $3K off $40K. They are a small family run business that select quality cars for importing. Based on that the savings they can pass on will be lower than somewhere bringing in cheap cars and marking them up. Depending on purchase price, $1K doesn't sound unreasonable on the surface.
Great to deal with... went there when we were looking for an Elgrand.
At the end of the day they are car salesmen though. They did try and advise my father in law, after we got our Elgrand from JSPec and he wanted one and went to see them, that we would never be able to register the one we got in VIC and especially not as an 8 seater... wrong.
great cars there - i nearly bought my r33 from them
someone mentioned trade in - i might look at that actually - cos no one is buying my r33!!!!!
I'm not so sure about a trade in.... They offered me 5k lower than what I actually sold my R33 for lol...
bought an R34 from there today (by the way hello all, new here)
spoke to Peter Evans who was the one selling us. they moved about 4-5 cars in order to allow us to test drive, reasonable guys and seem to be into customer satisfaction a fair bit. have heard a lot of good stuff about them and the cars they sell are in good nic.
What's the rebuild got to do with SSV doing my compliance?
I didn't even import through SSV and I have no issues with Prestige Motorsport either, I had a wonderful experience with both importer and compliance workshops.
The engine went on me while I was on track, nothing to do with them at all imo.
ahh... track, i guess that kinda explains it.
didn't even mention geoff??
it's good to hear there's actually a reputable import yard around. the majority play their part in giving the import industry a bad name.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
