Guys,
Im plaining to put a rb25det gear box to my r30.[straight 6 cyl 2.4L]. and the same time im gonna upgrade the Diff front and back break system. just wonder gear box direct bolt to engine????
if any one know abt this...pls help. much appreciate. thanks
https://www.sau.com.au/forums/topic/318809-rb25det-gear-box-on-mr-30-pls-help/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
