Ericjayrol Posted May 1, 2010 Share Posted May 1, 2010 Hey, Im sorry if this sounds like a really stupid question that anyone with a license should know, but I have just never been sure. When your tyres say 55PSI Max press, does that mean it would be best for me to fill it to 55? Or does it mean thats just the max it can handle, but I should be putting in 50? Or am I way off and theres an ideal PSI such as 43 for certain sizes or something like that? I know your tyre pressure has an affect on petrol consumption, but im also told that your tyre pressure can have a HUGE impact on your speed and acceleration, so I was wondering about all this. Thanks for any answers Link to comment https://www.sau.com.au/forums/topic/318811-max-psi/ Share on other sites More sharing options...
C4NC3R Posted May 1, 2010 Share Posted May 1, 2010 That's the max they can handle, not the max you should pump them to. In general, for 17/18/19' rims, I go for 34-36 PSI, that's what we put in as a standard at Beaurepairs. Link to comment https://www.sau.com.au/forums/topic/318811-max-psi/#findComment-5209154 Share on other sites More sharing options...
Ericjayrol Posted May 1, 2010 Author Share Posted May 1, 2010 Thanks heaps Cancer... I'll keep my 34 at the 36 mark then. Link to comment https://www.sau.com.au/forums/topic/318811-max-psi/#findComment-5209178 Share on other sites More sharing options...
some_cs_student Posted May 1, 2010 Share Posted May 1, 2010 What tyre profile? Lower profile often means higher pressure, within reason On the 65 profile I run 36psi cold. On the 40 profile I was recommended 38-40psi cold. Link to comment https://www.sau.com.au/forums/topic/318811-max-psi/#findComment-5209308 Share on other sites More sharing options...
Ericjayrol Posted May 1, 2010 Author Share Posted May 1, 2010 they're just the stock tyres, so im gonna assume the figures that cancer gave were right under that assumption? Link to comment https://www.sau.com.au/forums/topic/318811-max-psi/#findComment-5209725 Share on other sites More sharing options...
some_cs_student Posted May 2, 2010 Share Posted May 2, 2010 they're just the stock tyres, so im gonna assume the figures that cancer gave were right under that assumption? I was recommended 38-40psi on 235/45/17 if that helps, 40psi was for an advanced driving course at Sandown, but everyone seems to recommend a slightly different amount so you will have to experiment Link to comment https://www.sau.com.au/forums/topic/318811-max-psi/#findComment-5211170 Share on other sites More sharing options...
Birds Posted May 3, 2010 Share Posted May 3, 2010 Experiment mate, but always gauge it on the tyre profile rather than wheel size. With standard tyres anywhere from 32-36 will be fine. Low profile (35/40) anywhere from 38-44 is not uncommon. When you get to know more about it, you will use different pressures for different situations. A good test you can do is to inspect the tyre wear after some time...if you have too much wear on the sides of the tread it means your pressures are to low, too much wear on the centre of the tread and your pressures are too high. Link to comment https://www.sau.com.au/forums/topic/318811-max-psi/#findComment-5211364 Share on other sites More sharing options...
Ericjayrol Posted May 3, 2010 Author Share Posted May 3, 2010 Thanks heaps CS student & Birds. That helps a lot, i'll try em at 36 and see what results I get. Link to comment https://www.sau.com.au/forums/topic/318811-max-psi/#findComment-5212055 Share on other sites More sharing options...
Mangune Posted May 4, 2010 Share Posted May 4, 2010 I put 36-38 in 45 profile tyres. I got recommened that from my brother (works at bob jane) Play with it to see what you like Link to comment https://www.sau.com.au/forums/topic/318811-max-psi/#findComment-5215057 Share on other sites More sharing options...
bubba Posted May 5, 2010 Share Posted May 5, 2010 On my old 225/50/16's I ran ~36psi cold, the 235/45/17's I ran at about 40-42psi and I've found my 235/40/18's like 45psi cold. Link to comment https://www.sau.com.au/forums/topic/318811-max-psi/#findComment-5216391 Share on other sites More sharing options...
Ten Four Posted May 5, 2010 Share Posted May 5, 2010 Lol, on my previous 33gtr i ran 50psi all round... Don't ask me why, just did. They were cheap arse china tyres tho so I could oversteer at anytime I wanted... Currently, I run about 40ish psi. Link to comment https://www.sau.com.au/forums/topic/318811-max-psi/#findComment-5216440 Share on other sites More sharing options...
Ericjayrol Posted May 5, 2010 Author Share Posted May 5, 2010 Thanks for the detailed explanation Bubba. Thank you all for listing what your running on certain profiles, it helps me get a good idea on the averages Link to comment https://www.sau.com.au/forums/topic/318811-max-psi/#findComment-5216477 Share on other sites More sharing options...
BeEnAr Posted May 7, 2010 Share Posted May 7, 2010 There is quite a bit of info on this around the web, a lot of people state the best tyre pressure for your tyres in terms of performance, wear and comfort is the MAX pressure stated on the sidewall of the tyre minus 10%. So under that assumption it would be 55 - 5.5 which is 49.5PSI. That seems a bit high for me, I would stick to between 36-40 PSI cold pressure. Link to comment https://www.sau.com.au/forums/topic/318811-max-psi/#findComment-5221250 Share on other sites More sharing options...
Ericjayrol Posted May 9, 2010 Author Share Posted May 9, 2010 Thanks Beenar, That helps, does anyone else agree with/heard of the 10% theory? Link to comment https://www.sau.com.au/forums/topic/318811-max-psi/#findComment-5222902 Share on other sites More sharing options...
GTS4WD Posted May 9, 2010 Share Posted May 9, 2010 WOW! Are you guys serious? I run 45-50psi on the rears at the track when I go drifting. And about 32-34 at the front (16" rim, 205-55) It depends very greatly what press to run. Factors like wheel alignment, driving style, driving conditions, quality of rubber and what you want to get out of your rubber. Have a look at the tyre wear on the rubber, where is it wearing first? Is it an even wear? Is it feathering on the tread blocks? For daily driving I wouldnt recommend more than 36 just to try limit fuel consumption. Tyre press is a comprimise betwee grip and tyre wear. Do you want you rubber to last? or do you want it to grip? Link to comment https://www.sau.com.au/forums/topic/318811-max-psi/#findComment-5223024 Share on other sites More sharing options...
PM-R33 Posted May 9, 2010 Share Posted May 9, 2010 Lately i've been running 33-35psi in the rear to get more grip on 255/35/18 (used to run 38psi). Seems to hold second on full throttle a lot better with only minor wheelspin now. Link to comment https://www.sau.com.au/forums/topic/318811-max-psi/#findComment-5223056 Share on other sites More sharing options...
Ericjayrol Posted May 9, 2010 Author Share Posted May 9, 2010 I want grip mainly, and I do ask these questions to get answers for both daily drive and track performance, because I drive it as my daily driver but also want to get into track soon. Link to comment https://www.sau.com.au/forums/topic/318811-max-psi/#findComment-5223076 Share on other sites More sharing options...
