Rb25det series 2 motor good cond standard turbo, wiring loom and computer, RB20 gearbox with exedy heavy duty clutch, custom ally radiator, 2 piece tailshaft, 300x600 front mount intercooler all to suit S13 siliva No pics everyone know what a engine looks like. call me to arrange a look at it as its all still in the car. $3500ono Located on gold coast. Call Andrew 0428341730
https://www.sau.com.au/forums/topic/318849-rb25det-conversion-kit/
  • 2 months later...
