First of all, i hope this isn't the wrong place for this discussion, i'm quite new to all this :rofl:
I bought an R32 GTS-T about 6 months ago and after a month or so, the central locking stopped working with the alarm. i dis arm the alarm and the central locking must be unlocked by the key.
Both work fine seperately still as turning the key in my door unlocks the passenger door and the immobiliser/alarm still blinks when i push the button.
i am certain it did at one stage have remote central locking, i didn't dream that :P
I have looked for a fuse or anything anywhere but have no idea what i'm looking for and where i need to look? if you need specifics like alarm brand and stuff i can go check it out but i'm hoping it's a fairly general topic that doesn't vary too much.
Thanks heaps for your time,
Sam
https://www.sau.com.au/forums/topic/318850-alarmcentral-locking/
Sam
what alarm system have you got, i had something similar happen to mine the power for the alarm system shorted when iturned the car and the eletric motor in the doors for central locking seized, i have a mongoose m80 series, $50 for a new motor and all good might be the same for yours?
thanks for the reply, but the central locking motors work fine when i turn the key. if i turn the key in the drivers door the lock still works on the passengers door. and same from locking and unlocking the drivers door inside the car i can see the passengers door lock and unlock.
any other suggestions?
The switch in the drivers door is working fine that is why the passenger door locks and unlocks when you turn the key, that is part of the car's factory central locking. The part that may be faulty would be the aftermarket actual central locking motor which would have been installed at time the when the aftermarket alarm was installed. This motor is contrlloed by the alarm system which locks and unlocks the drivers door, which then trips the switch in your factory central locking which we now still work, as you have explained.
Common problem and easy fix none the less.... :(
OOOHHH!! thanks :D i'm sorry to YTS i didn't realise that's what you meant! thanks heaps for the frther detail! i will definitely try to test the driver door motor tomorrow! :)
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
