hey guys i am thinking about selling mt r32 gtst skline.....possibly selling it cause i would like a change....but having said that im 100% happy to keep the car too cause it owes me a heap and all the bits ive bought are new so i know its all good....
mods that i can think of just quickly are.....
*NEW 500hp roller bearing turbo brand new
*NEW modofied exh manifold
*NEW 600x300x76 bar and plate cooler with 2.5 inch mandrell pipework
*NEW microtech lt12 plug and play ecu
*greddy type s BOV
*NEW custom aluminium oil/air seperator
*New 500cc injectors
*NEW malipassi RR fuel reg
*NEW 600hp brass button 5 puck clutch(i can chirp 5th gear at like 120ish)LOL
*kyb climb struts with rsr lowered springs(handles awesome around the track)
*alloy strut brace
*hi/low boost switchable boost controller
*endless brake pads
*hks power flow air filter
*3 inch mandrell bent exhaust with a custom dump pipe for the new turbo
*sweet stereo inc alpine head unit jvc amp and magnat 12 inch sub and pioneer and sony speakers mixed up brands but it sounds great
*enkei RP02 17x8 forged lightweight racing wheels with near new tyres
*NEW autometer pro comp 30psi boost guage
*interior trim is the same as a gtr32 the sweet felty stuff which is rare in a gtst
*NEW hi intesnity led single stage shift lite mounted in the instrument cluster
*currently making around the 300rwhp on 15 psi but will be upping the boost to around 22 psi soon.
heaps of other bits and pieces too but thats the main things i can think of at the moment....
**id like a sr20det silvia or 180 but a rexy would also be nice.... i guess anything thats worthwhile getting is always good ,the price i have to sit down and work out if someone is serious about buying the car all i can say for now its over 20k which may sound steep but the car should be seen to be appratiated.... mild ones in the trading post still go for ~20k in some cases at yards so i think that mine is a reasonable price given its condition and modifications.... thanks Jon :headspin:
  • Replies 45
just thought id tell yas i just added a new thermo fan so bye bye vacum clutch fan :) and i also got a new radiator cap and redid all the cooling system as a precautionary measure with it been summer at the moment...i also had the air con all checked out too... :headspin:
still for sale trade after been stuffed around by perple needing finance ... isnt it always the way hahaha :) could be interested in a swap plus cash if its not of even value intrested in mostly anything really thats worth while... just feeling like a change :D
im honest when i say it should run a hi 12... it has been due to run at willowbank for ages but weather has been bad of late.... only time will tell but... its just fast enough for something u can drive every day or like 300km's like i did last weekend... :P
as my location says im in s/e Qld toowoomba to be precise... id only be intrested if its sr20det manual and in sweet condition.... and it wouldnt be a straight swap...cheers Jon
i read other posts about your car it sounds okay but im in qld and u are act.... doesnt really worry me but it may make it a bit harder....depends how keen u are i spose...
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that green thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
