  • Replies 88
Posted Images
What the hell wait up. I thought there was only two of them built, one of them is with Holden and the other was bought by old mate in Cairns for $900k. So which one is that?
Edited by PM-R33
Yep. Most expensive car sold in Australian history. $920,000 if you want an exact figure.
http://www.caradvice.com.au/11677/australi...ar-the-hrt-427/
Hence what the f**k is one doing on pickles auction site. It is either the one Holden owns (which the said they would never sell) or Chooka in Cairns is selling his.
Edited by PM-R33
Hard times at Holden I guess. guess the value of your mate's car just dropped :(
Lol I doubt Holden would be selling their only proof of ever building one (assuming they don't have one hidden some where that no one knows about).
It's most likely Chooka's or something, I dunno. Or it could be a very good replica.
Edited by PM-R33
F**k im an idiot! After looking over all the photos it is a replica :(
Key points:
Engine bay - That aint the C5R 7.0L with a carbon fibre trumpet manifold not to mention all the other differences (strut brace, throttle body, coolant overflow bottle, firewall heat insulation etc etc)
Registration - Can't be registered but it says it is
Seats - No red inserts on the seats
Fuel cap - not the silver aluminium one
And a bunch of other minor differences. Very strange that they haven't written "REPLICA" or something anywhere.
Well that settles that, im off to bed.
Edited by PM-R33
The mystery case is open again... LOL
Will we ever discover the origins of the Holden Monaro Test car at Pickles auction? Or will the mystery go unknown once it is auctioned off?
Stay Tuned! on SAU! :(
Key points:
Dont know where you get the idea that its a replica.
Its the real deal.
I have seen this car and its the one and the same
I dont want to sound dense here guys but what exactly is this car ?
Cheers boys,
Mitch.
Its a kind of impractical taxi with only 2 doors and very poor fuel economy. The ultimate example of why there is no point putting lipstick on a p1g.
I wouldn't bet on it being a replica - given that there were only two built, there's every chance they're both unique in terms of specs.
Its the real deal.
Well shit there you go. Never realised that the two cars were different. Kind of sucks that for $920,000 there is so many things missing on that car. The trumpet carbon fibre manifold is a work of art on the other one.
Wonder how much it will sell for....
Edited by PM-R33
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
