Car is a 93 R32 Skyline GTR
Build date 05/1993
Imported back in January 2008.
I am the first owner in AUS.
Car came into the country with 76,321KM on the clock, it now has 103,xxxKM.
Most of which is highway driving.
I'd like to keep it but its barely been driven over the past year due to my current situation.
I believe its also too clean/straight to be extensively modified or turned into a track hack. Regardless the cost would have been out of my budget and I wouldn't be able to enjoy it anyway.
So I've decided to let her go and focus on one car only this year.
Here's a list of a few mods the car has. Nothing special or major.
RB26DETT - 103,xxxkm
HKS air filters (09)
HKS intercooler piping
Blitz dual SBC 1bar set boost.
MINES tuned ECU (no speed cut and higher RPM limit which I'm yet to hit.....)
New water pump (08)
New Timing Belt (08)
Cometic head gasket
Factory dump pipes feed into 60mm twin front pipes and into a 3.5 collector. Currently has a 3" test pipe.
3.5" CAT back Jap brand of some sort.
Car made 212rwkw shortly after arriving into the country. Boost controller wasn't setup properly at the time, boost was about 0.6bar give or take.
Ohlins adjustable shocks on what seems to be stock springs.
Nice firm yet comfortable ride.
Sways are stock with a few new bushes here and there.
Car still handles a little boat like. More than I'd like anyway.
Factory HICAS and ATTESSA.
Kumo KU36 225/50/16 with plenty of rubber.
NISMO 320km/hr dash
NISMO gear knob not included :(
The steering wheel and original gear knob has the usual wear on it.
Looks a bit torn up but I'm sure that's normal....I dunno maybe someone can comment.
QFM race pads
Brake fluid flushed with Lubrimax fluid.
ADR approved Braided Brake lines.
Cross drilled rotors front and rear.
Pedal is much firmer and you can stop with some confidence.
There's probably more stuff but I haven't driven the car in so long.
Always serviced on time with a full syn oil, 20w50.
Asking $19,750
Price is the way it is because I'd like to avoid tyre kickers and low ballers.
Hoping the car will go to someone who can really appreciate how clean it is.
If you're serious, I'm more than happy to discuss the price and any aspects of the car further.
On with the pictures!
PM me for further details or email; niggseh at gmail dot com
https://www.sau.com.au/forums/topic/318872-qld-1993-nissan-gtr/
Mate this is my dream car! I've been keeping an eye on 32 GTRs for years, good to see them in good condition still, it's a credit to you... If this was in Perth I would jump on this!!
Good luck!
hey mate,
how come the head gasket was changed?
Cheers
Thats just like asking why the timing belt was changed at 100k..
It was just time for it to be changed. Normally when the timing belt is changed its better to change the head gasket at the same time as half the work is already done to get to it.
This will definetely sell soon !! Only if i had another 4k and wasnt going overseas lol
Where are all the serious people at :)
I don't think those who could afford to, want to at the moment.
Everyone else who wants a GTR just wants it to go fast and don't care about much else.
I blame global warming.
Patience buddy, my GTR took 7 months to sell. Doesn't help with the apparent "GFC". :(
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
