  • Replies 40
Posted Images
i'm getting a 1 piece made up for the ceff , i just need the length between the uni joints (or the welds to the uni joints) before you cut it to fit the 180 . Hehe :D , i have a rb25det to laurel loom already :ninja: (thanks for the offer , i'll take you up on that when it comes time to do the ceff :wub: i'm gunna need all the help i can with that one!! )
edit: actually , you should swap me for me r33 and a31 tailshaft , then you have a tailshaft to put back in the laurel with an rb30e+t and 5spd like i think you should :blink:
Edited by toffy
  • 6 months later...
so did i :( , it's ok , i can already tell i wont own it long , thought i'd try something different ... i think know i will own another c33 , this time with a sunroof :ph34r: . the s14 will pay for me to go to japan though :D i have plans of owning a c33 over there and bringing it back as a personal import :whistling:
not that it matters but, why not just sell the c33 if cash is needed not swap for a 2 door...?
also u need a paid parking spot for 12 months if you want a personal import not sure if you can leave japan then come back at the right time to export
^^ You jhave to actually prove you lived in Japan and drove the car regularly for a year, on top of registered ownership IN Japan to bring a car in via personal import.
Sadly its not as simply as buying a car and waiting a year before it goes onto a container.
If it was, I'd definately be cheating the SEVS rules and bring in a turbo manual AWD C35 Laurel.
Edited by Nic_A31
  • 3 months later...
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
