Anybody interested in this?????????
I have tried to make this work for my PNV Coupe & bounced it off Stagefummer in NZ and we both think it's too much trouble to impossible to fit to anything other than what it was designed for.
The strut top pieces obviously mount to the top of the struts and would then be in a plane 90 degrees to as pictured, the straight bar is then attached via the bolts off the top mounts and the cross bars mount to the 1st 2 pieces and mount to pre drilled holes in the floor (I guess for child restaints) making a very rigid rear strut tower assembly.
I have this brace and am just looking for interested parties at present, but if there is sqillions, maybe I should reproduce it and share it around.
Cheers, D
https://www.sau.com.au/forums/topic/318884-mr30-skyline-hatch/
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
