hello guys.
I have a problem with my R34 GTT it seems to have developed a issue after driving for
30mins (It doesn't happen when the engine is cold)
The engine starts drop in power when the boost comes on at around 3000rpm you can hear
the exhaust slightly popping and the power drop then after about 4000rpm the boost is OK.
I just had a major service done and my mechanic said he fixed a miss fire issue but
it still happening.
Any of you guys have a similar problem?
https://www.sau.com.au/forums/topic/318885-r34-gtt-miss-fires-on-boost/
Sorry Guys ... i just noticed you have a similar thread on this issue , I'll look into that for some answers.. please delete this thread if possible..
Cheers
Pac...
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
