  • Replies 193
Ah cool - I'd love to work in a place that has something to do with cars
For the love of GOD dont become a mechanic! I love my job, but fark it fustrates me! Lol. Great balloon shots, btw.
Mat, thats the best use for a Falcon I've ever seen :ermm:
Thats prety cool, would love to see what the second one would look like in hdr form....
Hmmm.. I could try but its only a single exposure so don't think I'll be able to get too much detail out of the foreground hey
Haha no I wont! Hate working on my two cars as it is.
ps cheers :D
^ excellent bike shots. Love the 2nd last one. Natural lighting or flash used? looks like flash in the last two, but could be wrong.
I only borrowed it for the day. So much fun tho!! Its a great lens.
I was looking at fish eye lenses on eBay, and found a whole heap of add-on lenses for less then $50. What are your thoughts on these, guys? They attach to the end of your existing lenses. Cheaper then $600 for a new lense, but dont want anything dodgy.
Go easy on me, I'm still learning the basics of my DSLR.
Taken with Nikon D60 on our recent trip to Port Douglas and the Daintree. What I really learned was to take good shots I had to use the manual focus because all of the tree branches and stuff caused the autofocus to fritz.
Here are a couple of ones that I thought were ok for an amateur. Croc was "Scar Face" on Daintree River Croc Cruises, Lizard was on a full day 4 WD tour (called Boyd's Dragon) and Golden Orb was freakishly huge - as big as my hand.
IMO they are a waste of money, and have limitations/distortions/vignetting caused by the imbalance between the lens and the add on.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
