Guess I'll save for a decent one then. Cheers, mate.
Eric, some good shots man!
With the auto focus, have you tried focus lock? With those kind of photos, set the focus point to, say, middle. Aim it at the item you're shooting so it locks on (dont frame it, just aim at that point), press the button half way, hold the button in that position and move to take the photo. It'll keep that focus, and save time manually focussing! Its a trick I use cos I'm half blind. Never too sure if its focussed right or not.
  • Replies 193
Yeah, I tried switching from Matrix to point. Problem was that a lot of the nature photos had Crocs behind a few leafs/twigs. I tried shooting a few shots with auto - all crap. Then went to manual and would take a few at slightly different focus - all looked ok through the view finder. Of course, generally all of them were a little off which is why I only posted some of the better shots on auto. I've still got a lot to learn :blush:
You'll get there mate. I've been shooting for just over 6 months now, and I've learn a lot in that time. Just listen to Sam, Sidd and Zennon and you'll be right.
Sam, awesome shot!
Well look who decided to show up... How's stuff over there sam? Nice pano's btw
Hello hello. so far so good! Getting used to a new town but heading off to Europe tomorrow for a month, then back to London to find some work..
Thought I better start adding to these monthly photo threads! So many awesome photos on here, very nice work. I really need to get some practice!
Nice shots mate, I like the graf one with the R33, would look even better without so many reflections in the car though. imho.
How long are you over there for, Sam?
Took these tonight. Not awesome, but definately a start. Technique I can work on:
Next time I might find somewhere with less lights. Or kick them out... Its the guetto anyway, it'd be normal to see people kicking lights :ermm:
Sam can start a 'many cans from different lands' thread :P I'd be up for that. Good to hear all is well dude!
My 50mm 1.8D arrived today. I'm busy packing/moving and I've been working off site for most of the week so no real time to play with it properly.
Here's the only shot i've tried so far. brenizer effect on the car just outside of the garage. Not so sharp as it was all hand held in very bad light. But the technical mumbo jumbo behind it worked well. SO expect something nice over the next week (if i get time :) )
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
