Yeah, I tried switching from Matrix to point. Problem was that a lot of the nature photos had Crocs behind a few leafs/twigs. I tried shooting a few shots with auto - all crap. Then went to manual and would take a few at slightly different focus - all looked ok through the view finder. Of course, generally all of them were a little off which is why I only posted some of the better shots on auto. I've still got a lot to learn :P
Yeah common issue. Best way to avoid this IMO is get in the habit of zooming in on the view finder three or four times depending on the camera and then check what it looks like. You might have to take one photo you know is sharp using a tripod or something so you know how many times you can zoom in on a sharp photo before it doesn't look good any more.
Does that make any sense? lol
  • Replies 193
Nice shots mate, I like the graf one with the R33, would look even better without so many reflections in the car though. imho.
Thanks, Yeah I agree on the one with the graff, will attach the PCL next time to cut the reflections see how it comes out. Cheers
The birds head is soooo sharp, looks great Sidd... The colours are pretty blown on my moniter, the yellow and reds especially.
I think its just the feathers like that. Coz honestly i havnt done any editing to it, well apart from usual raw processing, like brightness, contract etc then change to jpeg.
Will look at the high-res file tonight and see hmmm.. Also i use a IPS panel monitor, and looks fine. Not to sure tho, will re-check. Cheers for that feedback.
Oh and used a macro lens for that shot lol and focused on the eyes only.
Two more:
Edited by siddr20
Awesome macro shots, Sidd.
I've gotta ask, how close can you be to the subject to get a fully-filled frame and still be in focus, especially with a 180mm focal length? I've got a 100mm f/2.8 USM Macro, and sometimes feel as if I can't get enough detail while still making sure the frame's filled enough.
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 😛   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
