Hey everyone,
I have been looking for white dials for the dash cluster for an R34 for bloody ages and i can't find any, does anyone know where to get them from?
I'm talking about these things:
http://www.bmgauges.com.au/r32%20skyline.html
http://www.bmgauges.com.au/r33%20skyline.html
But for an R34...
https://www.sau.com.au/forums/topic/318920-r34-white-dial-inserts/
Some of those or an actual replacement dash with white gauges? Because that's all i can find for R34's, the Nismo white face dash, but i'm not keen to spend $1000 on a dash and then not have the kms matching the car. I just want the white gauges lol
Have seen them before on an R34...trying to remember who's it was though... :)
It depends what you buy...if its just the plastic face of the gauge, you just take the speedo/tacho/etc needles off, new face on, needles back on and recalibrate it...if you swap the entire cluster, the odometer is an independent unit that can be swapped into the new cluster, or there easy ways or changing the odometer reading itself.
try
http://stores.shop.ebay.com.au/Castle-Hill...m-Options.html_
contact them and they may be able to help
Thanks for that Garry, i contacted them and it turns out the bloke has been working on them for 34's and will be putting them up for sale tomorrow, so i am officially his first customer! :)
let me know how you go! and depending on how it turns out, i will give it a go!
Ok so turns out i'm still on the hunt, the guy said he was unable to replicate them successfully because of the shape of the dials. Makes sense as to why none exist for 34's as of yet... Damn Nissan and their making the dials complicated :D
Haven't tried, why's that?
i want to make it look like this, either spraying it silver or making a insert for it. i know it wont be the exact same as the gtrs one if i spray it but it will look nicer i think
if you do open up your cluster can you tell me if its easy or not.
i was thinking about this the other day when i was staring at my cluster in traffic..
pretty sure its too hard to do because of the concave shape of the dial face :blink: its a no go, just go for some white led's, i have some blue leds in mine at the moment but there are some spots that are slightly brighter than others.. annoys me
anyone know of white dash leds that have a consistent level of illumination across the whole cluster?
Yeh that's why the guy couldn't replicate them. Bloody Nissan.
Awel, i might just go for the silver surround... Would look better with the white dials but what can you do. I've also got blue LED lights, white won't work because the dials have a blue coat on them that turns the white light into a pale blue. Did you get the lights off Dan (666Dan) on here? His kits are quite good
pretty sure its too hard to do because of the concave shape of the dial face :whistling: its a no go, just go for some white led's, i have some blue leds in mine at the moment but there are some spots that are slightly brighter than others.. annoys me
could be the crappy positioning of bulb holes at the back of the cluster seems like there needs to be at least 2-3 more holes to give more light. ive done a few colours on different cars and always same result.
Wouldnt mind new faces for the 2 clusters also, triple gauges on 34's are pretty old/boring looking. but instead of white i would prefer black maybe glossy but then could reflect too much light?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
