Greetings all
I haven't been on in a while..
I'd like to thank the literally 100s of SAU members that have purchased and sprea :) the word about our little manual boost controller.
It was featured in a thread about 5 years ago and it continues to create discussion..
http://www.skylinesaustralia.com/forums/go...ntr-t73375.html
Many of you have wanted to know when I would bring out a dual stage and I am happy top announce that version one is ready to.
This model enables the driver to toggle between standard and an adjustable high boost at the flip of a switch. Standard boost on this model is not adjustable without a manual controller, only high boost is adjustable.
Our website is under construction so right now theyt are listed on ebay for $119 plus $8.50 registered post..
Discount to SAU means only $95 plus $8.50 post = $103.50 total
Either purchase on ebay and get the discount or email direct at turbotech@aanet.com.au for payment details.
many thanks for your support..
Mark Williams
https://www.sau.com.au/forums/topic/318939-turbotech-boost-controller/
oo nice. Do you have more information about it?
How does the switch work? Does it ground the solenoid etc? I want to wire it into a failsafe system and interested to know how I can trigger to switch to standard boost. (ground, 5v etc)
Thanks
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
    • Hi Luke, haven't thought about it a lot, trying to get the car into the paint shop first.  Did you want to make an offer? As stated above, I'm just looking for fair market price.
