:bonk:
My skyline has served me well, but it looks like after six years it will be sold by the weekend..........
Im just tossing up what to get now?
I dont think anything is going to fill the void.
The top of the list so far is a
Jeep Wrangler!
But yeh i still have no idea...
any suggestions? i have anywhere from $20k-30k to spend...
i will go back to skylines (r34 gtt probably one day), but right now i cant decide...
am i mad ? :headspin:
https://www.sau.com.au/forums/topic/31894-life-after-skyline-can-it-be-done/
the ones with the massive wheels are interesting... especially when they're shiney black with chrome bits and huge wheels...
not this big, but you get the idea :)
edit -- these are the wheels i was talking about :)
Do what I've done for the last 10 years. I always loved my Nissans but I also go snowboarding, mountain biking, fishing, etc. and needed a 4WD. In '93 I introduced myself to the cult world of Suzuki Sierra ownership which enabled me to also hang on to my Skyline at the time. Now I've owned 3 and my bro still has the first one I got, an '83 with Toyota 5K and headers. My current one is a '97 coil sprung that I bought new and traded my Ti on it. Never regret the Suzi, do regret selling the Skyline. A few weeks and I'm back my old position.
By the way, my Suzi has a 2" lift and 235 Kuhmo's and I still haven't found anywhere I can't go.
Yeh mountain biking too...
but the sierra is a bit small, and the wrangler has a 4 litre 6 six cylinder :)
although its a bit of an old design;
4.0L In-line overhead valve 6-cylinder
Fuel System Sequential multipoint Electronic Fuel Injection
Power (kW @ rpm) 130 @ 4,600
Torque (Nm @ rpm) 296 @ 3,500
Compression ratio 8.75:1
Capa have a bolt on supercharger kit for $6000!! :ak47:
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
