Get the genuine nissan head gasket and then since u already have the engine apart get the head ported and polished, highstrenght valve springs, bronze retainers, 264 duration cams, chrome molly valves etc.
Dont know cost of a stock head gasket but an aftermarket copper is around $400 at the moment
https://www.sau.com.au/forums/topic/31896-head-gasket/#findComment-641807
inasnt: she's trying to save costs you goon, not build a race car!
carlie, you should be able to get it fixed if you are lucky for $500-$800 or so - and assuming no further damage. New motor would be around $1k at least for an RB20DET
https://www.sau.com.au/forums/topic/31896-head-gasket/#findComment-641822
Predator lol you put that reply in such a funny way you have me laughing big time :wassup:
thanks for all the replys guys im really hoping it is just the head and im going to get the motor pulled apart so somebody can tell me, are they easy to pull apart i have a friend whos a mechanic but he is a holden mechanic lol :Oops:
i am really just trying to save money but maybe i have to realize cheapest is not always the best ohhhhhhhhh im really confused :P
https://www.sau.com.au/forums/topic/31896-head-gasket/#findComment-641863
Who's the happy man now ! :P
Unless you build a car INASNT, otherwise i really think one from Nissan will just do the job fine, but best to get hold of an imported one, not something from Repco.
https://www.sau.com.au/forums/topic/31896-head-gasket/#findComment-643215
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
