a lot of mechanics should be able to do them, or at least tell you where to take them to get done. it is pretty common and they don't have to know anything about imports to do it as the process is the same whether the car is an import or not.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
