hey guys just wondering if anybody else has had this problem and would anyone know how to fix it. Ive recently purchased my gtr the problem iv got is that the climate control works but temp doesnt vary, it changes on the display but actual air blow out stays the same.
Has anyone heard of this before and would they know how to fix???
https://www.sau.com.au/forums/topic/319003-heater-doesnt-blow-hot-air/
  • 3 weeks later...
check to see if the incabin temp sensor is connected, if it is not connected the A/C will always blow cold air because it thinks the cabin is hot as fk.
Incabin temp sensors increase in resistance when warmer, so with the temp sensor disconnected, there is infinite resistance i.e. break in circuit hence.
Also another point of failure is the air mix door solenoid/actuator as others have pointed out
