Hi guys,
Would you reccomened me importing an mr2 turbo from japan? or would it be cheaper to buy one? I've been reading that it's hard to get a car landed for less 10k and most MR2's seem to be around 8-13k.
I have seen MR2's in japan around 2k.
The MR-2 turbo (SW20 model) is not allowed for import to Australia with the current laws. The only MR-2 you can import is the earlier AW11 model built in 1988 or earlier, so if you wanted an SW20 turbo then you will have to buy one locally unfortunately.
  • 4 weeks later...
Serious?? O.O
i was going to import a mr2 gts from Japan...
oh man, all the gts and even the older gt version are so expensive in Australia.
And i thought we can import them because Australia didn't produce any mr2 >.<
if it's ban from importing, what is the reason? emission?
The import laws are fairly simple for this sort of car ... they are not allowed for import under the SEVS laws because the SW20 model MR-2 was sold in Australia in full volume (different engine makes no difference), so the only other way it could be imported under would be the pre-1989 laws however the SW20 was not built as early as 1988 so that is out too!
no you couldn't. :blink: doesn't matter if it's from canada or west africa for that matter. same rules apply. even if it did make a difference (which is doesn't) LHD would just make it even more of a hassle.
they are not exactly a big dollar car over here. there is a big range in price but a early 90s turbo model is $10K and up and a non-turbo under $10K no problem.
I imported an SW20 mr2 in feb 2006. It would have been one of the last ones to come into the country. It was done under the old 15 year rule, after it was abolished, thanks to a bloke who had stocked up on a heap of vehicles knowing that the rules were soon to change.
Anyhow, despite a good report from the agent, it turned out to be pretty rough.
Even if importing was still an option for these cars, i wouldnt recommend it. The costs are likely to be about the same as buying locally.
They are an old car now. The ability to test drive one, and have it properly checked out, is godsend.
sound advice backed with actual real world first hand experience. :D what more can you ask for?
anyway, as above importing is no longer an option so in this case the choice is made for you.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 馃槈. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 馃槏.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 馃檹 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 馃槈. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 馃槏 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
