hi i'm new in this forum, i'm from america and i need some help with a haltech system that i have, i know this company is from australia that's why i'm posting here to see if any of you can help me or pointing me to the right direction..
i have a haltech platinum sport 1000 for my s14 sr20det, the car strat up with the stock ECU but doesn't want to with the haltech it look like it doesn't have spark, if any buddy here know how to work with this systen let my know and i send you the base map that i'm working with...
thank you for any help,,, and i'm sorry if i post in the wrong place
https://www.sau.com.au/forums/topic/319011-need-dome-help/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
