Got my track spec (uncomplied) DR30 that i have no time for anymore..
Rebuilt less than 2000kms ago with..
Forged pistons
Machined/Balanced bottom end
Light head work
To4E with external gate and screamer
Big injectors
Motec ECU
Made 200kws on its first tune since rebuild (has more in it)
Fresh Gearbox
Extreme Heavy Duty Puck Clutch
Locked R200
Hydraulic Handbrake
BRIDE drivers seat
Stripped interior (sound deadening, Carpet Etc)
No back seat
6 point bolt in cage
17x8.5 in mesh rims with good tread.
Or random 15/16's depending..
Plenty more but i can't think of anything else at the moment
Email: [email protected] for more info/ pics
Looking for around the $8/9K mark
Only reason for selling i bought a GTR and work has the better of me time wise at the moment.
https://www.sau.com.au/forums/topic/319012-dr30/
    • My Neo turbo only went last year. Not 35 years old, to be sure - closer to 25. But still.
    • There's no way they left the factory like that. In R chassis there is nothing stopping the steering wheel being put on one spline out from straight, and then adjusting the steering arms to "correct" it (sort of). As well as the indicator cancelling there would also be an issue with how tight you can turn in one direction to the other. The other (less likely) possibility is that the "clock spring" (the circular electronic part that allows the wheel to turn while still having an electrical connection for horn and any other buttons like cruise) might not be in place correctly. I don't have any pics of the R33 (or Stagea) setup but there would be a circular locating tab which sits in the steering column to have it straight...if that is not seated properly then the indicators may not cancel at the right point (and, you might also get a HICAS error since it would think you are driving in circles)
    • It will mostly be bad scoring on the bores, which you can almost certainly fix by machining for oversize pistons. I have to say, I am super surprised that any standard turbos made it 35 years down the track before exploding!
    • Thanks for the info mate was thinking 255/35 rears and 235/40 fronts
    • What's the difference? I would have said that between the front and rear axle lines, there's no noticeable diff between a GTR and an NA 2-door.
